tohatsu 3.5 won't run without choking - Page 4 - SailNet Community
 1Likes
post #31 of 65 Old 08-24-2009
3.5hp
is this siimilar to evinrude 3.3?
mattosdf is offline
post #32 of 65 Old 12-25-2011
Resurrected thread. Found that new carb for 4hp Tohatsu is $108. Rebuild about 40-50. I haven't heard anybody point out that the Tohatsu/Nissan is almost impossible to throughly clean. The choke butterfly, carb intake butterfly linkage and choke linkage are plastic and I have not been able to remove them from the carb body prior to soaking the carb in cleaner (and I'm not sure it won't melt in carb cleaner). Factory manual is weakly written for 'how to' but does give assembly order and specifications. The idle jet is under a brass plug and can be difficult to remove. The main jet often corrodes in its' threads and the brass screwdriver slot can give way before the jet releases. If. any reader has solutions to the above I'd sure like to hear them. I hate to replace the carb every few years and fortunately I've just found a source for alcohol free gasoline a couple of blocks from my house which may extend the time between cleanings.
Diamondjet is offline
post #33 of 65 Old 12-26-2011
Hinterhoeller HR28
pvanv1's Avatar
Difference btw M3.5B and MFS4
Diamond,
The OP was talking about the old 3.5B, with slide type throttle. Yours is an entirely different animal. We clean them all the time (few a week) in my shop. Must be done in carb dip. Period. Better yet, if your carb was abused by letting gas sit in it too long... for your MFS4... would be to install a new carb for the MFS6B (identical powerheads), and clean up the old carb as a spare. 50% more hp, too. We do it all the time.
Paul Van Voorhees
Certified Tohatsu TLDI Technician
Mgr, Obersheimer Sails
Buffalo, NY USA
pvanv1 is offline
post #34 of 65 Old 12-26-2011
pvan1.....do you remove the plastic parts prior to carb dip? I found the manual did not refer to this and the plastic parts don't just 'pop' off. The choke butterfly appears to be press fit in a slot on the intake side and the levers for both throttle and choke are apparently press fit on pins. Is that the way it is??
post #35 of 65 Old 12-26-2011
captflood's Avatar
GREETINGS EARTHLINGS sounds like your treating the symtoms and not the curse it must need an extra fuel fillter if there is space for it GO SAFE
captflood is offline
post #36 of 65 Old 12-26-2011
I'll replace fuel filter and try it. Idling is poor on both my '05 Nissan 4hp and 2001 Tohatsu 5hp. Nissan just got the carb and new fuel filter. Tohatsu in my shop now. BTW...............How important is ethanol free gasoline?
post #37 of 65 Old 12-26-2011
captflood's Avatar
GREETINGS EARTHLINGS Always let your fuel sit for a while before you put it in the tank too let the water seperate then fillter then place in fuel tank GO SAFE
post #38 of 65 Old 12-26-2011
skygazer's Avatar
Can't buy ethanol free gas around here that I know of. Captflood, what do you do with the water at the bottom of the gas can if it separates out? Isn't it part gas part water?
Burn pile??
skygazer is offline
post #39 of 65 Old 12-26-2011
Burn pile??
Berryman's B-12 fuel additive "absorbes" the water and it goes out the exhaust. No affiliation, it just works for me for many years, no fuel related problems during that time. Suggest reading the instructions, it can melt paint and some plastics, good stuff!!, they will probably ban it in California soon, it works that well.
Dabnis
dabnis is offline
post #40 of 65 Old 12-27-2011
captflood's Avatar
GREETINGS EARTHLINGS. Any leftover deposits or fluids that are unwanted and are in need of dissposal I normaly feed to the weeds in my drive (Dandylions Mainly), Or go into a bottle used to wash-down engine bits, GO SAFE
Nissan / Tohatsu 6h 4 stroke audeojude Outboard 261 09-08-2015 05:59 PM
New Dink, Looking at Tohatsu 3.5 Sapperwhite Gear & Maintenance 43 06-30-2009 06:38 AM
Make offer or run away? eherlihy Boat Review and Purchase Forum 56 10-03-2007 02:36 PM
Refrigeration—Part II Selecting a System Tom Wood Gear and Maintenance Articles 0 05-19-2003 08:00 PM
What to Do When You Run Aground Sue & Larry Her Sailnet Articles 0 12-18-2002 07:00 PM
