tohatsu 3.5 won't run without choking - Page 6 - SailNet Community
 1Likes
post #51 of 65 Old 12-27-2011
LakeSuperiorGeezer's Avatar
In Wisconsin the premium gasoline (91 octane) does not have any alcohol.
LakeSuperiorGeezer is offline
post #52 of 65 Old 12-28-2011
Hinterhoeller HR28
pvanv1's Avatar
Originally Posted by dabnis View Post
Paul,
I can only speak from my own experience.I put some gas in a coffee can, added some B-12 fuel additive, and the water was no longer visible, apparently blending with the gas to be burned away? As mentioned earlier I have used it for many years in many different motors, both 2 & 4 stroke with no fuel related problems. Of course, using it is voluntary, and your mileage may vary
Dabnis
Quite possible. We get the same effect from the K-100 additives, which we sell and use. The K-100 is an emulsifier of some kind, and not a bad thing. However, with E gas, once it has separated, you can't "put the genie back in the bottle". The alcohol is used as an octane booster, amongst other things, and the "restored" fuel will still be below octane specifications, causing other problems as well. It's a cheat that may get you by. Still preferable to run fresh, clean gas.
Paul Van Voorhees
Certified Tohatsu TLDI Technician
Mgr, Obersheimer Sails
Buffalo, NY USA
pvanv1 is offline
post #53 of 65 Old 12-28-2011
What are your thoughts on something like this:
Cabela's: Nissan Fuel/Water Separator and Replacement Filter
Dabnis
dabnis is offline
post #54 of 65 Old 12-29-2011
Hinterhoeller HR28
pvanv1's Avatar
Dabnis
I sell them and recommend them.
Paul Van Voorhees
Buffalo, NY USA
pvanv1 is offline
post #55 of 65 Old 12-29-2011
OK, so noted. Thanks for the reply.
Dabnis
dabnis is offline
post #56 of 65 Old 07-31-2012
LittleDevil's Avatar
Re: Difference btw M3.5B and MFS4
Diamond,
The OP was talking about the old 3.5B, with slide type throttle. Yours is an entirely different animal. We clean them all the time (few a week) in my shop. Must be done in carb dip. Period. Better yet, if your carb was abused by letting gas sit in it too long... for your MFS4... would be to install a new carb for the MFS6B (identical powerheads), and clean up the old carb as a spare. 50% more hp, too. We do it all the time.
Sorry to dig up an old thread, but I have a 2008 Mercury 3.5HP 4 stroke. Will this carb (MFS4) fit that as well? Thanks!
Writer/Director/Producer
Skype
LittleDevil is offline
post #57 of 65 Old 08-01-2012
Hinterhoeller HR28
pvanv1's Avatar
Re: tohatsu 3.5 won't run without choking
Nope. The 3.5 4-st is the "big brother" of the 2.5, and is already upgraded.
Paul Van Voorhees
Buffalo, NY USA
pvanv1 is offline
post #58 of 65 Old 08-01-2012
Okay thanks. Well I changed the plug, cleaned out the tank, cleaned out the carb, cleaned out the petcock, cleaned out the lines, cleaned the air screen, blew out and cleaned the air lines that run to the bottom of the engine compartment and put fresh premium fuel in. I wasn't sure how many turns to put on the one screw in the back of the carb, so I screwed it all the way in until the spring bottomed out, and then turned it out 2-3/4 turns, which from memory, should be about right. I put the tank back on and now I can't get to the adjustment screw. Seems like a dumb design but oh well.
I started it right up and it actually idled great with the choke off. Problem is that it still will not run once you throttle up, unless you choke it about half way. I opened the fuel cap to see if that helped. Same deal. This is what it was doing before. Has anyone figured this out? I was pretty meticulous about cleaning out all parts of the carb and jets, although I could not figure out how to get the float off without breaking the clip that holds it on. I did my best to spray that out and confirmed cleaner was squirting out another part of the carb.
I got this motor as a package with a sailboat, and it has never worked right. This is the second time I've tried cleaning it. Oh and I recently read about an inline filter. That is one thing I did not find. Can anyone tell where that is and how to take it out, clean or replace it?
Any other advice here?
Skype
post #59 of 65 Old 08-01-2012
I had a Honda 2HP. It had a very small fine mesh filter inside the fuel line just at the tank outlet. You can't see it from the outside. Yours may be similar?
Paul T
dabnis is offline
post #60 of 65 Old 08-01-2012
I'm guessing you just pluck it out? If so, how do you get it back in? I'll dump the fuel and take a look. Thanks.
Skype
Nissan / Tohatsu 6h 4 stroke audeojude Outboard 261 09-08-2015 05:59 PM
New Dink, Looking at Tohatsu 3.5 Sapperwhite Gear & Maintenance 43 06-30-2009 06:38 AM
Make offer or run away? eherlihy Boat Review and Purchase Forum 56 10-03-2007 02:36 PM
Refrigeration—Part II Selecting a System Tom Wood Gear and Maintenance Articles 0 05-19-2003 08:00 PM
What to Do When You Run Aground Sue & Larry Her Sailnet Articles 0 12-18-2002 07:00 PM
