03-03-2008
Willing to Learn
Originally Posted by Faster
Marine outlets sell a foil backed foam sheet about 1" thick that can be glued to the engine box walls with contact cement. It comes in sheets about 36"x60" IIRC, depending on sales, at between $60-$90 per. Leaving the foil exposed makes for a clean bright engine space.
We used to have our air compressors surrounded by lead-lined rubber curtains.. haven't seen these commercially but they worked great The material is quite heavy, about 1/8" thick and probably as effective as the 1" foam. It's also very good to use as curtains to block off some areas that do not have a solid surface available.
Another trick we used in a previous boat was to drape an old dentist's Xray blanket over the engine. This was extremely effective noise control, and made no difference to the operation of the diesel other than you have to make sure the blanket doesn't/can't block the air intake. We had to remove it for routine service, but that was a minor inconvenience.
Thanks, the X-ray blanket is a unique idea. Overall I think that leaded rubber is a good material, especially if it's backed with a foam material as an isolator.
I'd really rather have some sort of rigid material for ease of installation. My boat is rather unique in that the engine sits just below the companion way and is covered with a wooden box that is removable to expose the entire engine. It makes for super accessability but adds to the overall noise level. Fortunately when I repowered two years with a new Beta it was supplied with rubber isolated engine mounts and the four cylinder just naturally ran quieter than the old three cylinder Volvo.
