barrier coat - Page 11 - SailNet Community
post #101 of 105 Old 05-18-2009
Send a message via AIM to T26Rich
I wrote this up a while back, and it can be used to allow you to properly "hotcoat" the bottom paint as well as properly barrier coating the bottom.
If I under stand it, it takes two days then. First day for the main areas, second day for the jack stand areas after moving stands, unless its 90 degrees out all day.
T26Rich is offline
post #102 of 105 Old 05-19-2009
Maine Sail's Avatar
It's done in stages. IPK2E has a six month open window for hot coating IPK2E to itself but bottom paint must be done at thumbprint dry which can be tough on a large hull.
On my hull they barrier coated day one. Day two, after 24 hours, moved the stands and applied shrink wrap plastic to the heads and barrier coated a second coat. Day three, after 24 hours, moved stands back to original location barrier coated. For hot coating the paint they did the last pad spots after the two coats of paint had cured for two days then moved the stands and did barrier coat and paint hot coated at the pad spots. When all was said and done she had five coats of IPK2E and two coats of hot coated ablative copolymer paint. At 68 - 70 degrees it took two guys. One to get the last coat of barrier on and the otehr to follow shortly behind to begin hot coating paint. At 68-70 it kicks off in less than an hour to thumb print dry so you really need two people to do the last step right if it is near room temp.
______
-Maine Sail / CS-36T
Maine Sail is offline
post #103 of 105 Old 05-19-2009
T37Chef's Avatar
Maine...I think I see a spec of dirt on your hull...WTH is going on??????
Shawn
T37Chef is online now
post #104 of 105 Old 05-19-2009
That's cause he didn't do the bottom job... he contracted it out...and they left the dirt there...
sailingdog is offline
post #105 of 105 Old 05-20-2009
Bottoms
Hello all,
Just read the entire thread and thought I'd toss in some personal experience. I work in a boat yard and do quite a bit of bottom stripping etc.
Hopefully this won't bring on more lawsuit crap here, but every boat that I have sanded down that had 2000 for a barrier coat had loads of blisters just under the 2000. Like the 2000 was letting water in but not letting it back out. I get in arguments with the other yard guys regularly about it as it's still the only barrier coat we seem to offer here. I get the inproper prep reply often but many of the boats come from many other yards. I couldn't fathom that everyone was doing it wrong so I re-read the directions on the 2000 can numerous times. For some reason, possibly it's just been added, I'd never noticed some small print that says to go to their website for their "full" tech sheat instructions if desired. I advise anyone considering 2000 to go to the site themselves and check it out. First of all, they require an initial coat of their own straight epoxy before the 2000, along with other pretty rigid steps to the point that I doubt any yard has ever followed, even if they'd somehow known the steps existed.
As far as major blister problems, I'd advise going with stripping the gellcoat. Gellcoat is 99% of the time polyester resin which is not as waterproof as epoxy resin. And the problem with blisters is that the water supposedly changes chemically when trapped in with resin to the point that it will almost never really dry out without incredible effort and months to years in a rediculously dry and warm environment. We've just trialed a new electric mechanical stripper and have to say it is the cat's meow. It's actually a paint stripper which is simular to a grinder but has 3 triangular blades which do the stripping. One guy took the entire bottom gellcoat off a 37 foot Pearson in about 6 hours. Damn near a perfect removal to the glass on his first time using the tool. It's called a paint shaver pro and came mounted on what seems to be a Hitachi grinder body. You can check it out at American International Tool Industries, Inc. LLC | Makers of the Paint Shaver Pro paint stripping, paint stripping tools, paint removal, paint removal tools, paint scrapers, lead paint removal, stripping lead paint, infrared paint heater. I'm not affiliated with em, but highly recomend it. Shaved to the glass quicker than even just sanding off the bottom paint alone. And it came with a vacume attatchment. Be prepared with ALOT of vacume bags but very little mess! Amazing tool.
Back to barrier coat. I will be going with straight West system epoxy on the Wanderer next winter. Just don't trust the whole microplatelet thing. How can millions of mechanic bonds to microplatelets be more impervious than a solid barrier completely chemically bonded to itself? Seems like a marketing gimmick to me. And as far as epoxies, I've seen MAS and can't say anything bad about them, but I absolutely love West System. I have never, ever heard anyone have West System fail. The only reason to me to even think about trying anything else is price, and these days there's just not enough difference in price to consider it. Hell, if all boats were built entirely out of West there wouldn't be a boat yard in business anywhere.
trecksail is offline
Barrier Coat & Antifouling paint shipley Gear & Maintenance 7 08-09-2009 09:18 AM
Applying Barrier Coat Sixbrothers Gear & Maintenance 3 02-12-2008 09:23 PM
Barrier Coat - Amerlock 400 by Ameron ? dougshipl Gear & Maintenance 5 12-31-2007 01:10 AM
Is Vinyl Antifoul better over Epoxy Barrier Coat pds Gear & Maintenance 3 08-27-2001 12:27 PM
Barrier Coat stupidgringo Gear & Maintenance 0 08-23-2001 04:53 PM
