barrier coat - Page 8 - SailNet Community
post #71 of 105 Old 07-02-2008
You're probably about 275 sq. ft of surface area or so... as a really rough guess. As for how many gallons it takes to barrier coat that, why don't you call up MAS Epoxies and ask them. I'm sure they're worked with people doing this previously.
Thanks, Dog, I have a call in to Tony, hit the voicemail, but will probably hear back from him shortly. I figured that there is probably some formula or rule of thumb for estimating the area. One post said a fellow had done his 40' boat with six gallons but his boat is much larger than mine.
I am kind of thinking that two gallons of resin and a gallon of hardener will get the job done. I may get three gallons or resin, a gallon of hardener and a spare 1/2 gallon of hardener, just in case, and if it is not needed I can take it back to Jamestown Dist. I understand that this material is pretty thin so a little bit will go a long way.
Any idea on how many rollers this job might take? I am planning to do the whole job in a 24 hour period. Also, someone mentioned using black electric tape instead of masking tape to edge the boot stripe, what do you think of that idea?
Thanks,
Bob
AA3NK is offline
post #72 of 105 Old 07-03-2008
Use the good 3m Blue masking tape. Get lots of roller covers, trays and mixing containers. What I've found works fairly well for mixing is GladWare containers... and you can usually recycle them by popping out the hardened epoxy after it cures completely.
The reason you need lots of roller covers, trays and mixing containers is that you need a fresh set for each batch of epoxy you mix up. If you re-use a container that has older epoxy it, it will cause the new batch to kick prematurely IIRC. If you buy the roller covers from Home Depot, rather than a marine supply store, they'll be cheaper and you can return the unopened packages of them that you didn't need to use.
sailingdog is offline
post #73 of 105 Old 07-03-2008
Freesail99's Avatar
I mixed about 16 oz. of epoxy up at a time and used a 6 inch foam roller to apply. I suggest the moment you finish applying that coat or part there of, epoxy, you pull the foam roller off the handle and wipe the handle down, or you'll never get the roller off or another one on. I used 3 bags of 6 rollers each to do my bottom.
S/V Scheherazade
Freesail99 is offline
post #74 of 105 Old 07-03-2008
Senior Moment
SailorMitch's Avatar
Thanks,
Bob
I'm probably the guy who suggested using black electrical tape, which is what MAS recommended to me.. the epoxy will stick to masking tape and may glue that tape to the hull, making for another clean-up job. epoxy will not stick to the electrical tape. but if you are calling MAS anyway ask them again.
SailorMitch
Sailing winged keels since 1989.
1.20.09 Bush's last day the end of an error !! Hopefully we still have a constitution and economy left by then.
"Compassion and tolerance are not a sign of weakness, but a sign of strength." The Dalai Lama
good planets are hard to find-- a song by steve forbert
I have but one lamp by which my feet are guided, and that is the lamp of experience. I know no way of judging the future but by the past.-- Patrick Henry.
SailorMitch is offline
post #75 of 105 Old 07-03-2008
Barkeep - Sailor's Pub
craigtoo's Avatar
Send a message via AIM to craigtoo Send a message via Yahoo to craigtoo Send a message via Skype™ to craigtoo
Don't let the blue masking tape stay on for long or it will be an absolute PAIN to remove.
I left it on for a week once and that was a disaster. It removed some of my waterline as well...
-C2
1987 Sabre 34 "Saoirse"
Meet me at the
I love
craigtoo is offline
post #76 of 105 Old 07-03-2008
The trick is to remove the blue tape within a few hours of finishing up the barrier coating. The blue stuff has worked well for me on three different boats that were barrier coated, one with IP2000E, one with Epoxy and one with something else.
post #77 of 105 Old 07-03-2008
craigtoo's Avatar
Spot on SD.
I applied 14 coats of epoxy.. so it took a while... (in the winter you have to wait for the right temp..)
After learning that lesson.. I peeled the tape and and reapplied after after every 2 coats (which is about 12 hours).
-C2
Meet me at the
I love
craigtoo is offline
post #78 of 105 Old 07-03-2008
BTW, it depends on which blue tape you use.... they make them in various grades. The one we used for my boat was the long term one and can be left on almost two months without much problem.
post #79 of 105 Old 07-03-2008
craigtoo's Avatar
Oh.
Mine was just blue... you always get the good stuff...
-C2
Meet me at the
I love
craigtoo is offline
post #80 of 105 Old 07-03-2008
Just FYI-
Scotch-Blue™ Painter's Tape for Delicate Surfaces #2080 1 in x 60 yds (36 rls/cs)
This tape removes cleanly without adhesive transfer or surface damage for up to 60 days, even in direct sunlight. It is a low-medium adhesion tape that is ideal for smooth, freshly painted surfaces, faux painting, wood floors and glass.
Barrier Coat & Antifouling paint shipley Gear & Maintenance 7 08-09-2009 09:18 AM
Applying Barrier Coat Sixbrothers Gear & Maintenance 3 02-12-2008 09:23 PM
Barrier Coat - Amerlock 400 by Ameron ? dougshipl Gear & Maintenance 5 12-31-2007 01:10 AM
Is Vinyl Antifoul better over Epoxy Barrier Coat pds Gear & Maintenance 3 08-27-2001 12:27 PM
Barrier Coat stupidgringo Gear & Maintenance 0 08-23-2001 04:53 PM
