Cleaning bottom in water??? - Page 3 - SailNet Community
post #21 of 46 Old 03-05-2008
If you've got an ablative paint on your boat, don't scrub it with a scotchbrite pad... you'll take a lot of the paint off unnecessarily doing that.
sailingdog is offline
post #22 of 46 Old 03-05-2008
I don't discuss my member
Fstbttms's Avatar
Completely dependant on the degree of fouling. Ablatives aren't special, they get just as dirty as anything else and a dirty ablative bottom isn't going to be cleaned with a piece of carpet any better than an epoxy bottom would. But ablatives are soft and you do need to take care with them, regardless of what you clean them with.
Fstbttms is offline
post #23 of 46 Old 03-05-2008
djodenda's Avatar
Fstbttms:
Any advice on changing zincs? My diver has become unreliable, and I am thinking about doing it myself until I can find another one....
David
1987 CS 36 Merlin "Kyrie"
djodenda is offline
post #24 of 46 Old 03-05-2008
the pointy end is the bow
erps's Avatar
I scrub my own bottom periodically and change my own zincs. I bought one of those T-handle allen wrenches specifically for the zincs. Easier to hold on to while wearing gloves and something to tie a lanyard on to. When I do my shaft zincs, I scrape the shaft to make sure it's clean, tighten the zinc down snug then tighten each side in increments to keep it even. After all that, I bang on it with a hammer to make sure it's really seated and then tighten it again. I'm an amateur though, so if fastbottoms does it differently, he's probably right.
Ray
S.V. Nikko
1983 Fraser 41
La Conner, WA
erps is offline
post #25 of 46 Old 03-05-2008
Fstbttms's Avatar
Dress warm.
Fstbttms is offline
post #26 of 46 Old 03-05-2008
Fstbttms's Avatar
Originally Posted by erps View Post
...if fastbottoms does it differently, he's probably right.
No, you pretty much nailed it.
Fstbttms is offline
post #27 of 46 Old 03-05-2008
JimsCAL's Avatar
I use one of those pads with a hand grip used to clean barbeque grills. Similar to a rough Scotchbrite pad but much easier to hold onto.
JimsCAL is offline
post #28 of 46 Old 03-05-2008
not-so-old salt
tonybinTX's Avatar
fstbttms (or anyone else) - what cleaning schedule would you recommend for warm fresh water (central TX)
"The God I believe in isn't short of cash, Mister." - Bono
tonybinTX is offline
post #29 of 46 Old 03-05-2008
Fstbttms's Avatar
Fresh water? Sorry, I don't have a clue.
Fstbttms is offline
post #30 of 46 Old 03-05-2008
I use a soft sponge for my ablative paint. Scotch bright works for the prop and shaft but seems too harsh for the rest of the bottom. A soft sponge willknock off most stuff and doesn't remove that much paint. Again my bottom is ablative. It can be done with a snorkle but I scuba dive and it is much easier that way. I stress that you do not want to scrub off the paint!!!! The whole ideal of an ablative paint is that it comes off easily so that nothing hard can attach to your hull. Once you start getting hard growth the boat needs to be hauled and repainted. Hard paint is different. Once the copper leaches out the paint is useless and stuff will grow. I have never found any hard growth on top of ablative paint. The sponge is just to remove the slimy soft growth that will slow you down.
MoonSailer is offline
Mooring systems GoodOldBoat Good Old Boat 5 08-25-2015 10:36 PM
Cleaning Water Tanks JouvertSpirit Gear & Maintenance 5 03-14-2007 11:37 PM
Winter Storms and Hypothermia Michael Carr Her Sailnet Articles 0 02-26-2004 08:00 PM
Cleaning Fiberglass Hulls and Decks Sue & Larry Her Sailnet Articles 0 03-07-2002 08:00 PM
Water Ballast/Manufacturer RSJ Boat Review and Purchase Forum 6 03-07-2002 06:59 PM
