03-04-2008
Marcusn-
The leaking portlights may be causing other serious issues, besides getting the cushions wet. I'd look into repairing them sooner rather than later. Leaking portlights can also add to mold and mildew buildup in the boat as well. If it is the hardware around the ports that are leaking, it may also be allowing water into the deck's core, if you have a cored deck and cabintop. If that's the case, it may be rotting the deck core, and that leads to a delaminating deck... a very expensive repair usually.
