  #11 (permalink)
Old 03-04-2008
Freesail99's Avatar
Freesail99 will become famous soon enough
When I removed the traveler on my boat the bolts took a lot of pressure before they broke free. The 8 bolts were also 7.5 inches long.
S/V Scheherazade
  #12 (permalink)
Old 03-04-2008
brianbourgeois's Avatar
brianbourgeois is on a distinguished road
good old vinager!!! soak it down 6 or seven times over a day to let it penatrate then try to tighten a hair then loosen.
  #13 (permalink)
Old 03-04-2008
sailboy21's Avatar
sailboy21 is on a distinguished road
Yeah.. I had that battle once. I no longer have a traveler.
  #14 (permalink)
Old 05-13-2009
tager's Avatar
tager is on a distinguished road
I would use naval jelly. No, not from your belly button...
Of course I have this problem with the old head outlet valve being corroded on the thru hull. I alternate between miracle mystery oil and naval jelly. It is not working.
  #15 (permalink)
Old 05-14-2009
delan's Avatar
scurvy dog
delan is on a distinguished road
There's a CRC product called "freeze off"
lowers the temp of the target, and then allows the penetrant to wick into the threads.
But you can't expect to spray it and work immediately, It needs time and possibly a few applications, but it works.
Whilst I'd rather not use heat on a boat, if nothing else is working, I cover the thread with wax, then hit the nut with the torch, then remove the heat before the wax has burnt off.
The wax wicks into the crevice as the assembly cools.
If this doesn't work, drill or air chisel the are the only things that will.
  #16 (permalink)
Old 05-14-2009
hellosailor's Avatar
One hopes that thirteen months after the post was made, the answer is old history and the point is moot.
Of course, running battery cables to things might just have ARC WELDED them together, beyond any hope of disassembly.
  #17 (permalink)
Old 05-14-2009
delan's Avatar
scurvy dog
oops
  #18 (permalink)
Old 05-14-2009
delan's Avatar
scurvy dog
Now that I think about it, it's not so bad to answer old posts, if someone with a similar problem does a search, they'll get more info. That has to be preferable to the same questions getting asked repeatedly.
  #19 (permalink)
Old 05-14-2009
merc2dogs is on a distinguished road
That's always been my view, after all, someone was most likely digging for answers when it was revived!
I've seen a lot of threads that were actually answered long after they were put to rest.
Ken.
cleaning aluminum water tank rbtpfe9 Gear & Maintenance 18 12-27-2010 11:31 AM
Keel Bolts Repair/replacement chartscharts Gear & Maintenance 11 08-07-2006 03:53 PM
Keel Bolt Repairs Don Casey Gear and Maintenance Articles 0 11-10-2003 07:00 PM
Keel Bolt Concerns Don Casey Gear and Maintenance Articles 0 10-12-2003 08:00 PM
