03-06-2008
Yes, the alternator will fry the AGM batteries... It will eventually dry out the absorbed electrolyte...leaving the batteries very nice, if large, paperweights. Why not just add a regulator to the alternator??? In the long run, it'll be a lot cheaper than replacing the AGM batteries regularly.
I'd also recommend you change your starting battery to an AGM one, since the voltages for charging are slightly different. If you set them for the AGMs, you'll shorten the life of the wet-cell battery, or vice versa.
