Dodger Sticker Shock! - Page 5 - SailNet Community
 22Likes
post #41 of 91 Old 12-10-2012
Learning the HARD way...
eherlihy's Avatar
Re: Dodger Sticker Shock!
Cruiser2B - No worries. no offense taken. I was shocked myself!!
I have had lower estimates, using the existing aluminum frame, which was also crap. In for a penny, in for a pound...
This will be done and, I am sure, done right. We will all find out in the spring.
eherlihy is offline
post #42 of 91 Old 12-11-2012
davidpm's Avatar
Originally Posted by eherlihy View Post
T
I won't tell you what the estimate for the interior cushions was. That might kill you. I will tell you that it was a good deal more than the dodger and bimini. I also decided that I could live w/ out redoing the interior.
So now that you brought it up. What did you have quoted.
New foam, what kind?
Material, different or same top and bottom?
Cost (we can take it) its only an estimate not a bill
davidpm is offline
post #43 of 91 Old 12-11-2012
davidpm's Avatar
T
davidpm is offline
post #44 of 91 Old 12-11-2012
The total is slightly north of $7300...
Not trying to offend you brother but have you lost your mind?
I don't care how good somebody is, I can't wrap my head around that one
I'm not happy unless I'm complaining about something.
I'm having a very good day!
misfits is offline
post #45 of 91 Old 12-11-2012
Maine Sail's Avatar
Originally Posted by Cruiser2B View Post
did not mean to insult you, $7300 is a lot of money......to me. Amazed that there are people out there that can charge these prices.... and sleep at night...my guess is that he or she will sleep quite well. hope it turns out well. 5-6000 is a ton of labor! I hope you get 60-70 hours out of them at minimum.
Our dodger & Bimini was 78.5 hours....
Go to boat meet with client on specifics and take preliminary frame measurements (most boats are not right in front of the canvas shop)
Go back to shop to bend, crown & manufacture the frame
Go to boat and "test fit frame" for "aesthetics" and agreed customer shape/dimensions/height etc.. A good shop will often want to get agreement on the new frame before moving forward.
Send frame out for custom welded grab bar (not all canvas shops are capable of doing a "top shelf" welding job for a grab rail).
Go back to boat to install both frames, every hole needs to be properly bedded and sealed. Backing plate access for the dodger & bimini frame need to be available for a "proper" installation. This required taking much of the interior apart to gain access to the where the feet would be mounted. Some guys just use screws, I prefer through bolting and was glad to pay for this extra time....
Pattern for dodger & bimini (got windy and ran out of time in "calm" on our job and had to come back to complete it, this happens). I was there during the patterning. It took two guys 4.5 hours on the first round before it got too windy to continue patterning. I suspect another 2 on the next round...
Go back to shop and sew dodger. With W.L. Gore Tenera thread, which is what was used on ours, this can add up to two+ additional hours in labor alone during the sewing as Tenera is quite finicky through the machines.. I will NEVER, EVER use polyester thread again and am GLAD to pay a premium for Tenara thread....
Return to boat and install dodger & bimini. On our boat this took two guys nearly 8 hours, I was there during the installation. Remember every fastener needs to be properly bedded, mounted & sealed. The snaps, lift a dots etc. are all installed on-site so the fit is just right. The dodger MUST fit correctly and there is a LOT that goes into a proper fitting and installation to get it "just right". If any nip & tucks need to be done to the dodger or bimini it goes back to shop for more tweaking. If old screw holes from a previous dodger could not be used they are filled, and this can really add up..
Once the dodger & bimini were installed the patterning for the bimini connector piece could begin
Pattern for bimini connector
Sew bimini connector
Return to boat and install bimini connector
If it does not fit "perfectly" back to shop for "tweaks"..
With a quality canvas shop this is not a 20 hour process at $80.00 per hour it is closer to 65 - 80+ man hours at the going rate which around here is $75.00 to $90.00 per hour...
BTW my washing machine was just repaired and they charge $97.00 per hour + travel + make a 400%+ mark up on the parts... Not just a "marine thing"... My canvas guy actually earned his money compared to the flunky who changed a $3.00 sensor then charged me $68.00 for it + $218.25 in labor and $65.00 "travel" to come 9.5 miles from his shop.
My car repair shop gets $95.00 per hour to work "flat rate" which means the mechanic fixes it in 15 minutes and they still charge me for a full hour because that is what the shop rate manual tells them to charge..... At least with my canvas guy I pay for an honest hours worth of work.....
I just changed the transmission fluid on my car yesterday for total cost of $36.00 for four quarts. It took me about 20 minutes. The dealer wanted $185.00 and they ge the transmission fluid at their cost not the $9.00 / quart I pay for the "proprietary" fluid.......
davidpm likes this.
______
-Maine Sail / CS-36T
Maine Sail is offline
post #46 of 91 Old 12-11-2012
Ya know M.S., you're a good person & I understand that everyone needs to make money.
To try & justify $7,300.00 for a dodger, I think ya'll are snapping.
Cruiser2B likes this.
misfits is offline
post #47 of 91 Old 12-11-2012
Sabreman's Avatar
The bottom line is that owning a boat is expensive. This is why I do my own work, including canvas. There is no way that I could afford to own my boat otherwise.
Sabre 38 "Victoria"
Sabreman is offline
post #48 of 91 Old 12-11-2012
Maine Sail's Avatar
There are but two things I don't do on boats and that is canvas/sails and Awlgrip.... Sometimes you just need to pay the artist if you want it done right. I recognize I'll never be an artist when it comes to sewing...
______
post #49 of 91 Old 12-11-2012
Maine Sail's Avatar
You don't need to justify it but the numbers do add up.. Labor is labor and canvas making is one of the more labor intensive things you can do on a boat.......
______
post #50 of 91 Old 12-11-2012
chucklesR's Avatar
The dodger and bimini (full enclosure) on my Irwin is my living room.
chucklesR is offline
Hard dodger GoodOldBoat Good Old Boat 15 03-21-2013 01:20 PM
hard dodger vs. soft ktuthill General Discussion (sailing related) 15 10-01-2009 12:31 PM
Three ways to fix dodger windows GoodOldBoat Gear & Maintenance 2 11-05-2008 05:37 PM
hard dodger vs soft dodger bluetommy77 Boat Review and Purchase Forum 6 10-07-2007 06:29 PM
Replacement Dodger Hm2michaud Gear & Maintenance 3 02-16-2007 10:04 PM
