Like Tree16Likes
  #71
Old 02-03-2013
jimgo's Avatar
Asleep at the wheel
jimgo is on a distinguished road
Re: Dodger Sticker Shock!
Sumner, that looks pretty good! Better than my first sewing jobs.
Minnewaska, I think that's the better way to do it.
OK, one more dumb question - Can I template off the frame at home, or does it need to be done at the boat? That is, could I (or the canvas guy) take home the frame and make a template without the frame being on the boat? Just trying to think of ways the job could be made easier. When I tried to make a template for my companionway last spring, the gnats were brutal and made it almost impossible.
- Jim
Home: Western Philly 'burbs
1980 Allmand 31
1975 Albacore 15
  #72
Old 02-03-2013
You could probably rough the main canopy as long as you KNEW you had the same geometry on the mounting points as you do on the boat.. but you couldn't pattern the transition to the cabintop anywhere else.. AFAIK the pros all do this on the boat. Best results would be having the frame exactly as installed (therefore on the boat) and patterning the entire dodger there.
  #73
Old 02-03-2013
Minnewaska will become famous soon enough
....Can I template off the frame at home, or does it need to be done at the boat?.....
Same with most things. If you want it to come out right, you have to prepare it right.
The difference between canvas that is so tight you can't get it to properly wrap around the frame and canvas that looks saggy and loose is about a 1/4 of an inch.
I would do it in place on the boat.
Jeanneau 54DS
  #74
Old 02-03-2013
chef2sail's Avatar
chef2sail will become famous soon enough
On the boat in place.
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
  #75
Old 02-03-2013
jimgo's Avatar
Asleep at the wheel
I was afraid you would say that! Hmmmm... Gotta break out the heavy-duty bug spray.
- Jim
1980 Allmand 31
1975 Albacore 15
  #76
Old 02-03-2013
Sumner10's Avatar
Location: Utah (House & Macgregor 26 Classic) -- Florida (Endeavour 37)
Sumner10 is on a distinguished road
If we would of had the choice it would of been at the boat and the house, but our boat is 2200 miles from the house.
I took some measurements of the coaming that....
...goes around the cockpit/companionway and tried....
...to duplicate them at home and first setup the old dodger that was torn, old and had a number of zippers that didn't work. It worked pretty well, but as has been mentioned there isn't a lot of difference of being skin tight and loose (we are somewhere in-between).
We are happy with the outcome but one problem area was where...
...the bimini attaches to the dodger where the 2 left double arrows are. I didn't get the angle of the bimini in relation to the dodger quite right at home and..
... the bimini sits higher on the boat vs. what I had at home so we had to cut the area where they join on the sides (rolled up in the above picture) and modify that at the yard with the sewing machine. We did that just before we left and didn't put it back on, so no new pictures.
Our boat will sit for a good part of the year in Florida without us so we wanted the dodger and bimini to go on and off quickly for storage so all of the pockets....
....where they attach to the frame are zippered.
We also wanted the front window to have a lot of options. The screen can zip off and will be off unless we are using...
...the full cockpit screen. The window also zips completely out if you want and I put in 4 zippers pulls so that you can ...
...open the whole window and leave it in place (above) or open any one or two...
...areas of it. This all takes a lot of time. All of this is on the web site,
Sum
Our 37 Endeavour --- Our 26 MacGregor --- Trips With Both
  #77
Old 02-03-2013
SloopJonB's Avatar
Senior Moment Member
SloopJonB will become famous soon enough
If you've ever had a new top put on a convertible the prices of custom dodgers doesn't seem so out of line.
jimgo likes this.
I, myself, personally intend to continue being outspoken, opinionated, intolerant of all fanatics, fools and ignoramuses, deeply suspicious of all those who have "found the answer" and on my bad days, downright rude.
You may post attachments
You may edit your posts
Hard dodger GoodOldBoat Good Old Boat 15 03-21-2013 01:20 PM
hard dodger vs. soft ktuthill General Discussion (sailing related) 15 10-01-2009 12:31 PM
Three ways to fix dodger windows GoodOldBoat Gear & Maintenance 2 11-05-2008 05:37 PM
hard dodger vs soft dodger bluetommy77 Boat Review and Purchase Forum 6 10-07-2007 06:29 PM
Replacement Dodger Hm2michaud Gear & Maintenance 3 02-16-2007 10:04 PM
SEO by vBSEO 3.6.1
