What's on your Spring "to do" list? - Page 2 - SailNet Community
post #11 of 50 Old 03-09-2008
Wandering Aimlessly
PBzeer's Avatar
Main project is to ...... head north!
So far, there has been a real dearth of 23 yr olds. Heck, haven't even seen much in the way of 53 yr olds.
John
Ontario 32 - Aria
Free, is the heart, that lives not, in fear.
Full, is the spirit, that thinks not, of falling.
True, is the soul, that hesitates not, to give.
Alive, is the one, that believes, in love.
JCP
- Website & Blog
PBzeer is offline
post #12 of 50 Old 03-09-2008
In florida, I think 63 year olds are more the norm unless it's spring break and you're at one of the big beach cities.
sailingdog is offline
post #13 of 50 Old 03-09-2008
Maine Sail's Avatar
Installing
Spring to do.
Re-finish cabin sole (almost done)
Install 8 new New Found Metals port lights.
Re-plum Macerator
and many more...
______
-Maine Sail / CS-36T
Maine Sail is offline
post #14 of 50 Old 03-09-2008 Thread Starter
T37Chef's Avatar
Those will set you back a few boat units
Shawn
T37Chef is offline
post #15 of 50 Old 03-09-2008
Maine Sail's Avatar
Yeah about 2k shipped with all the butyl tape, machine screws and the counter bore..
But well worth it! The Beckson ports on my boat SUCK!!!
______
post #16 of 50 Old 03-09-2008
SaltwaterSuzi/CapnLarry
LarryandSusanMacDonald's Avatar
We gave up a long time ago on a 'list'. We have a notebook - and at the rate I'm finishing each task and checking it off, my calculations are I will have to live to be 237 years old to get it all done.
Saltwater Suzi and Cap'n Larry
"A sailboat is a fickle mistress. You’ve got to buy her things. You’ve got to understand everything about her. What you don’t know she’ll use against you." -Captain Larry
LarryandSusanMacDonald is offline
post #17 of 50 Old 03-09-2008 Thread Starter
T37Chef's Avatar
Agreed!!! Those beckson's do suck, I have the same. Before you get rid of them, what size are they? I may be interested in them for parts since 2k spent on port lights is far down on the list
Shawn
T37Chef is offline
post #18 of 50 Old 03-09-2008
Freesail99's Avatar
Install the 4 new 6v batteries and battery box I made. The yard where I am at has a battery cable crimper.
S/V Scheherazade
Freesail99 is offline
post #19 of 50 Old 03-09-2008
Northeast 25 O'day Owner
Birdface's Avatar
-Bottom sand/paint
-Wash/wax hull
-Remove old lettering and pin stripe
-Re-letter
-Add 2nd battery and battery switch
-Re-wire major electronics
-Attempt to drill/fill softdeck area
-Anchor mounts
-gel-coat repair some nose damage
-Replace rub-rail
-Install through hull fish finder/transducer on swivel mount
-New tiller
-New outhaul block and rigging
-New running rigging for all
-New sailcover
-Sand and treat teak rails
May (will) Not Get To:
replace 30 year old water system
full rewiring
solar charging setup
P.s. - When is the Boat Manager coming back to the site?
1976 25' O'day - "SeaWind"
Hello Sailor: "I've just learned that good boats, in good hands, are damned robust creations."
Birdface is offline
post #20 of 50 Old 03-09-2008
purveyor of mischief
sanctuarysam's Avatar
Originally Posted by Stillraining View Post
With all that energy I got a few things left to do I my boat for ya! That was one heck of a week..
the funny thing is...i had a blast doing this. it afforded me an opportunity to learn all of the boat's systems. quite honestly, all my previous boats were light outboard powered, if you needed power you ran an extension cord from down below, small gel-cell racing batteries, etc type boats.
so, what did i learn? that when your hot water heater bleeds out much of the anti-freeze, you have to wait until the thermostat opens and the radiator fills (read, no air bubbles) otherwise, hi-temp buzzing w/in 5 mins. i found out my #1 battery is mostly useless..juice flows through, but doesn't stick around. the water is still off in my marina, so i had to try to pressurize the water tank by hauling two 6 gal jerry cans w/ water.. (uhm, water still weighs 8lb/gal..so, do the math... i now have hot water...
i spent at least 2 hrs trying to figure out how best to use my three spin/whisk stanchion mounted chocks, so that when on deck, you don't spend time bent over to detach said poles.. i also figured the high aspect mounting provides additional safety features by having something substantial to grab, before you go overboard. easier to set the chutes that way too. snap,clip,lock and pull. and she is screaming. 720sqft asymm on a sprit, extending three feet forward, yet locked in place by the anchor chock and pin. gybing will now be a breeze. i can lose the parell beads off, and have a switchable set of spin lines, and extraneous lines are out of the way. down comes asymm, and up goes the 'halloween' spinnaker, both in socks...
i worked my ass off those many days but, never got to go sailing, although many attempts were made to cajole friends and fam to go..but low 40's and blowing like stink..well, no takers, and as much as i love sailing, this boat is a lot of work solo in 20+ breezes, which is what i had my available days. (ok..some will quietly say..."wimp"...but hey, it is what it is). for the past many years,my best friend from HS, randy, and i are incapable of picking sailing days that blow less than 20 kts. on the J/24, we went 'torpedo sailing' a blade and full main..and a wild wet ride. i have learned that i/we are no longer 20 years old and don't bounce back as fast anymore.
the last time randy and i went sailing, it was blowing a solid 25, w/ rollers from 4-6'..well, i had one of those descecant bags (think midew water, in a caustic solution) explode in my hanging locker..all my extra foulies, boots/safety gear, etc got a dose of nassy water. i had to get all that mess cleaned up and odor free.
but, all in all a successful outing, if i may say so myself.
By three methods we may learn wisdom: first, by reflection, which is noblest,second is by imitation, which is easiest,third is by experience, which is the bitterest.
Sam
Sanctuary, Sabre 30 mkIII
sanctuarysam is offline
Spring has finally sprung (again) / Spring Commission Check-Off list NewsReader Mass Bay Sailors 0 04-22-2007 05:15 PM
sailnet email list mikehoyt General Discussion (sailing related) 0 12-16-2004 06:27 PM
The Definitive Spring Work List Tom Wood Her Sailnet Articles 0 05-03-2004 08:00 PM
The Spring Launch Bruce Caldwell Gear and Maintenance Articles 0 04-30-2002 08:00 PM
The Spring Launch Bruce Caldwell Cruising Articles 0 04-30-2002 08:00 PM
