What's on your Spring "to do" list? - Page 3 - SailNet Community
post #21 of 50 Old 03-18-2008
RAGTIMEDON's Avatar
I tried the list, tried the notebook, and gave up to a good guess. Every time I finish something at the top of the list, two more are added to the bottom! Living to the age of 237 will result in a list I can no longer carry out to the marina.
Don
1980 Endeavour 37 sloop, currently in the Mississippi near St Louis
RAGTIMEDON is offline
post #22 of 50 Old 03-18-2008
Install a new VHF unit, lead halyards aft, convert genoas from pin stop to line-controlled genoa cars, install two hatches, install a steaming/foredeck light, fix the solar panel mounts, install an inverter/charger, re-do the AC electrical panel.
sailingdog is offline
post #23 of 50 Old 03-18-2008
Once known as Hartley18
Classic30's Avatar
Dock
Stuff that.. I'm off sailing - it's a beeeyootiful day outside!!
Classic30 is offline
post #24 of 50 Old 03-18-2008
Freesail99's Avatar
I need to re wire my mast, I have a new VHF to put in, drain the fuel tank and clean ( not looking forward to doing that ). Install teak mouldings that I made on the new countertop. New Head. Battery box and 4 6v batteries.
S/V Scheherazade
Freesail99 is offline
post #25 of 50 Old 03-18-2008
You suck...
post #26 of 50 Old 03-18-2008 Thread Starter
T37Chef's Avatar
You forgot something...
what about the fog horn
Shawn
T37Chef is online now
post #27 of 50 Old 03-18-2008
HerbDB's Avatar
Flying down to Florida next week to start bringing Split Decision back to Annapolis for the season. Nothing to uncover or reconnect this year.
Hope the northbound weather is good.
Herb DuBois
Beneteau 36CC
Split Decision
HerbDB is offline
post #28 of 50 Old 03-18-2008
Sea Slacker
Get the boat back home and go sailing
Then:
- replace main halyard winch
- service primary winches
- rewire NMEA connections
- install boarding ladder
- install refrigerator
- make new deck drains (and remove the current ones)
- add electric bilge pump
- may be have the mast taken down to re-route one of the halyards, replace turnbuckles and change the way lowers connect.
oh, need to replace the batteries but that's just money and heavy lifting
brak is offline
post #29 of 50 Old 03-19-2008
merttan's Avatar
First of all, safety projects;
-> I'm going to install a mounted radio since my handheld's range is not really useful out on the LIS...
I picked the Standard Horizon Gx3000S which is about $200. It has all the bells and whistles I can use around here like loud hailer with fog signals. Being under fog is not a entertaining experience with a 22 footer , especially if the route is going through ferry lines
-> New stanchion bases with wide base plates.
-> I'm going to check and change needed rigging.
-> Buy a smaller anchor and use the one I have for over nights and emergencies. The one I have is about 18 pounds danford, too bulky and heavy to use for quick stops...
And then there are cosmetic projects;
-> I'm going to renew the old cushions... And make new cockpit cushions.
-> I'm going to build a front hatch from fiberglass once I build a cast from the broken piece.
-> I'm going to build a nice looking teak or mahogany frame for the port lights. For both inside and outside looks. And install new lexans...
-> I'm going to build a custom fresh water tank to fit beneath the cooler which would be around 8-10 gallons with a water pump installed on it.
-> Buy a new porta potty... The one I have is getting stinky...
-> Install new headliners with wood trim effects.
Those are pretty much what I plan to do. So far all those projects are going to lighten my wallet about $800 and add about 100 lbs on the boat.
This summer I hope to sail slow in style
Oh shoot! i forgot the bottom paint, add another $300 to the total... Darn!
" I refuse to engage in an intellectual battle with an unarmed man!"
Materialism: Buying the things we don't need, with money we don't have, to impress people who don't matter.
merttan is offline
post #30 of 50 Old 03-19-2008
chucklesR's Avatar
Originally Posted by PBzeer View Post
Main project is to ...... head north!
So far, there has been a real dearth of 23 yr olds. Heck, haven't even seen much in the way of 53 yr olds.
If/when you make it to the Chesapeake stay away from my 54 year old
My spring to do list includes:
Hire a lawn service so I have more time to sail the boat.
Sail boat.
Work on tan, sun burns for bald guys suck.
chucklesR is offline
Spring has finally sprung (again) / Spring Commission Check-Off list NewsReader Mass Bay Sailors 0 04-22-2007 05:15 PM
sailnet email list mikehoyt General Discussion (sailing related) 0 12-16-2004 06:27 PM
The Definitive Spring Work List Tom Wood Her Sailnet Articles 0 05-03-2004 08:00 PM
The Spring Launch Bruce Caldwell Gear and Maintenance Articles 0 04-30-2002 08:00 PM
The Spring Launch Bruce Caldwell Cruising Articles 0 04-30-2002 08:00 PM
