- Quick Menu
03-20-2008
That explains a lot...
Originally Posted by cardiacpaul
I entered this life through the gates of hell... they didn't want me runnin' the place anymore.
—Captain Malcolm Reynolds, Serenity (slightly edited)
If you're new to the Sailnet Forums... please read this POST.
03-20-2008
My spring "To Do" list..... get the boat out of South Texas and head North for the summer!
04-20-2008
Northeast 25 O'day Owner
Hey all,
I'm halfway through my list, I just want to say thanks to all the resources and knowledge on this board... my projects are going smooth and I wouldn't have even attempted half of them without everyone's advice and support.
Launch is approaching!
1976 25' O'day - "SeaWind"
Project Pictures: http://cucchi.dotphoto.com
Hello Sailor: "I've just learned that good boats, in good hands, are damned robust creations."
05-08-2008
Hey-
Updates - Finished the list and then some. Did bail and hire some young yard guys to wet sand and compound. But it opened up a bunch of time for me to tackle custom making a fishfinder mount and swivel and installing. Also build a companion way board based drink holder.
I'll take pictures and post somewhere tomorrow.
After three years of ownership and countless hours here with all of your help the boat now looks like it's 10-20 years younger and it's at least 3 times safer than when I bought it.
Thanks everyone.
05-08-2008
Well so far....
Bottom painted
Hull waxed
engine serviced
Still on the list:
New teak hand rails
New teak toe rails
Those may have to wait until the fall.
05-08-2008
Professional Ignorer
Seeing the light...
Originally Posted by T37Chef
I will be doing the usual when its pulled in a couple of weeks - waxing
- bottom paint
- zincs
- stuffing box, etc.
and - hoping to get all the teak taken down and cetol (natural) applied
- 2 nicro vents installed
- am/fm radio installed
- repair lettering on transom
- new painted boot stripe
If I can get the done during my spring break week I'll be very happy.  especially for the Chesapeake rendezvous in June, boat must look good
I'm at that point that I am starting to get a little frustrated...due to work, weather, and family stuff (brother's getting married) we still have not had our first sail of the season, but hopefully this Sunday, even if its a quicky
The new name is on...
But I have finished so far: - Wax & Sealed hull and all vertical topsides (I tried the Starbrite Wax Cleaner as review in PS and sealed it with a new version of Interlux Teflon Wax Sealer, so far so good
) - Two Coats of Interlux Micron Extra w/ Biolux, and raised waterline 2"
- Petit Zinc Barnacle Spray on shaft & prop and new zincs of course
- Installed new LasDrop Shaft Seal
- Painted new boot stripe using Interlux Brightside, turned out well except for a couple of touch ups needed due to the travel lift slings
 - Sanded down all
exterior teak, applied 3 coats of Cetol Natural, 2 coats of Cetol Gloss...last coat to go on Saturday  - Applied Woody Wax to Non-Skid
- Moved 3500 GPH Bilge pump aft and higher in the bilge and removed check valve...then
- Installed a new 500 GPH Bilge pump down low in the bilge with a check valve (Thanks Sailingdog)
- Installed 2 Nicro Day/Night vents, one in the forward hatch, one in the Salon hatch. (Thanks again SD
) - Installed a new AM/FM CD MP3 Player in a new custom built teak box and replaced all the speaker wires. (thanks Cam)
- Installed new Standard Horizon VHF and connected to GPS for DSC
- Moved stern light from stern rail to antenna post (due to new davit last year)
- Removed name from stern and replaced with two vinyl lettering versions, one on each side of boat aft (really looks good, ask Sailor Mitch)
- a couple of other little things, new rub strakes on newly cetol'ed toe rail, patched a few chips in the deck gel coat, re-routed furling line down port side and yada yada yada.
Left to do: - Make a decision what to do about my chromed cowl vents, I am leaning toward new stainless from ABI
- Make a decision about sailing instruments, you may have read my issue with my prehistoric datamarine depth gage.
- Epoxy bilge; this may have to wait till the boats pulled.
A BIG THANKS TO ALL HERE WHO HAVE LENT THEIR KNOWLEDGE AND EXPERIENCE...MUCH MUCH APPRECIATED!!!!!
1982 Tartan 37C #358
05-08-2008
almost done with my list. hoping to get in the water next week.
completed items:
sanded, stained, cabin stairs
sanded and teak oiled, cockpit table & cup holders
installed new head
installed new holding tank, waste deck plate
installed all new head plumbing piping
rewired bilge pump
replaced depth & speed gauge w/gps/sounder
installed new transducer
installed battery voltmeter
replaced stern light
compounded, polished, waxed hull (actually suckered my dad into doing it) halekai, thanks for the instructions. came out pretty good for a first timer.
to complete, hopefully in the next week:
barriercoat & paint bottom
wchevron
'78 c-30
05-14-2008
Ok guys,
Finally snapped some pictures and collected three years of progress.
Three albums, one for each year I've owned her. The last of which shows the results of my spring list posted above.
SD - Thanks for help on the GPS/Fishfinder mount, look how it came out!
T37, I launch on Saturday. I can tell you how the new fishfinder works for depth replacement. I've mounted a shoot-through transducer and I'm curious to see if it can replace my depth gauge completely. (it better, my depth is DEAD 95% of the time and randomly works once in a while)
05-14-2008
05-14-2008
C&C Racer/ Cruiser
Replaced all lifelines with Johnson fittings and swaged them myself (126 turns with the rachet wrench)..cost $650 saved $750 off West marine or Annapolis Rigging quotes for the job
Replaced Hot Water Heater
Replaced Lazy jacks
T37Chef..look for us this weekend as we will be heading out Saturday with MYC Sailfleet companions for a mini-vous to: destination to be determined at 9 AM Sat AM. We are rafting up for the evening and bring appetizers and 3 bottles of red wine per boat.
Dave
Parkville, Maryland
C&C 35 MKIII
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
