Black Mold - Page 3 - SailNet Community
post #21 of 28 Old 04-10-2009
SD...
It's obvious that you're not enthusiastic about using Ozone, but it IS effective and no more harmful than chlorine. It simply doesn't take a high concentration to kill the mold, and for the hour or two it takes there is no damage whatsoever to anything other than the bugs. Further, the lingering odor, what there is of it, is delightfully refreshing.
Howard Keiper
Berkeley
thekeip is offline
post #22 of 28 Old 04-10-2009
It is as effective and chlorine is just as destructive, but chlorine bleach on ly goes where you apply it...ozone fills the entire boat and affects everything within the boat... which the bleach won't do.
Originally Posted by thekeip View Post
SD...
Howard Keiper
Berkeley
sailingdog is offline
post #23 of 28 Old 04-10-2009
That's the benefit of it.
hk
thekeip is offline
post #24 of 28 Old 04-10-2009
That's also the downside of it.
hk
post #25 of 28 Old 04-10-2009
jarcher's Avatar
Mold Away
I killed as much mold as I could last October, and have been killing more as I find it this year. I had a plastic instrument cover for my Nexus display panel that was black. I thought it was dirt. Nope, mold.
I gave it one spray with a product I bought at Boater's World called "Mold Away" and the black instantly vanished, leaving a remarkably clean white plastic cover behind. It was then that I learned that NEXUS was molded into the cover!
Anytime I see mold exposed, I use one squirt of mold away and its gone.
jarcher is offline
post #26 of 28 Old 04-10-2009
SD...
Touche!
hk
thekeip is offline
post #27 of 28 Old 04-10-2009
alwheeler98's Avatar
We found using the gigantic buckets of Damp Rid (the kind with the sawdust in the bottom), did a lot to minimize moisture issues over the winter season.
No musty smell in the boat this spring either.
Which is great, since I think there are only so many hours in your life that you should spend in a small, somewhat enclosed, area (like a boat cabin) using bleach as a primary cleaning product.
I think I'm pretty close to my quota.
alwheeler98 is offline
post #28 of 28 Old 07-29-2011
I have used a product for years, Kanberra Gel and it has keep my Pearson mold free. I'm not hooked on the smell, too much turpin for my liking. So as I researched the web I found a product on line (commercial link deleted) that has a great smell, cost less and lasts longer than the Kanberra. I have an 8 ounce container on my boat and with one of the solar powered vents, we have no mold. So far it has lasted about 50% longer than the KG. It's worth a try.
SailaroundtheKeys is offline
Bilge mold and where do I get that black sealing stuff... Hargadoo Gear & Maintenance 5 11-24-2006 10:02 PM
GALICIA - BLACK RIBBON - NEVER AGAIN Albatros CMF Gear & Maintenance 0 11-30-2002 03:57 AM
