Old 03-10-2008
nk235's Avatar
nk235 is on a distinguished road
Yanmar 3gmd Question
I had a 25' boat with an outboard but just put a deposit down on a 32' boat with an inboard Yanmar 3GMD. I do not know really anything about inboard motors but I do know Yanmar is very popular and makes a good motor.
I plan on having the entire boat surveyed but one of my concerns is this motor. The owner was a former mechanic rebuilt it less than a year ago and according to what he gave me he did:
Engine (Yanmar 3GMD 20 HP): The Yanmar 3GMD was completely rebuilt in 2007 to include NEW- Starter, Motor Mounts, Valves, Valve Guides, Pistons, Rings and Rod Bearings. Racor Fuel Filters, Fuel Lines, Fuel Pump and Engine Raw Water Pump have also been replaced
He says it runs perfectly and it only has 20-30 hours on it since the rebuild but my concern is that I do not know this person where is if the work was done by a yard I would have a warranty on the motor. Besides dropping the boat into the water for a sea trial, is there any other tests a surveyor or mechanic can do to see if this was rebuilt properly? Do surveyors usually include this? Is the Yanmar a complicated motor that I should be concerned with the fact that it has been rebuilt? How much does it usually cost to have a Yanmar mechanic inspect the motor? Is it worth it to do this or is the Sea Trial enough?
The rest of the boat is in immaculate shape and the owner has been very forthcoming about everything else so I believe him when he says it runs well, but I am not about to buy a boat on that. I want proof for myself. Any suggestions?
Thanks in advance
Old 03-10-2008
timebandit's Avatar
timebandit is on a distinguished road
You can ask for parts receipts and check the dates.
Old 03-10-2008
JohnRPollard's Avatar
Moderator
If you have serious concerns, it might be best (if only for peace of mind) to have a separate engine survey performed. This would be by a certified engine surveyor, not the guy/gal you've hired for the rest of the boat.
Personally, I would consider it a plus if the engine had been properly re-built. A bigger concern to me would be whether this particular engine is raw or fresh water cooled. You might also ask what precipitated the re-build?
Also, most 3GMs I'm familiar with had a higher HP rating (our 3GM30F for instance is 27hp peak, 24 hp continuous), but yours could just be an older version that I'm not familiar with.
Good luck to you!
Old 03-10-2008
timebandit's Avatar
Check the log book.
Old 03-12-2008
billangiep's Avatar
billangiep is on a distinguished road
The 3GMD is raw water cooled unless a heat exchanger was added at a later date also I beleive the 20 HP rating is @3400 and the 22HP is @ 3600.
"QUICKLINKS"
ModelHPfromto
YSE8 & 1219741976
YSB8 & 1219761977
YSM8 & 1219771980
2QM202219751980
1GM7.519801983
3GMD, 3GMF22.519801983
3HMD, 3HMF 3019801983
Need help YANMAR engine mount Giulietta Gear & Maintenance 20 04-15-2010 01:15 PM
Another Yanmar 3QM30 question hertfordnc Gear & Maintenance 1 10-17-2007 09:33 AM
Smoke on the Water - Yanmar Question DrB Gear & Maintenance 7 09-04-2007 05:31 PM
Yanmar - fuel injection pump question rperret Gear & Maintenance 7 05-24-2007 10:00 AM
Prop for Morgan OI w/ Yanmar 3GM30F cwarwick Gear & Maintenance 1 11-16-2004 01:17 PM
