The mystery of the Marine Environment - Page 3 - SailNet Community
post #21 of 32 Old 03-15-2008 Thread Starter
chucklesR's Avatar
Omatko,
I concur, some things you NEED marine grade for. I'd not use soft iron on my rigging. My knife is stainless steel. My TV is Walmart.
chucklesR is offline
post #22 of 32 Old 03-15-2008
billangiep's Avatar
When in the market for a FM/CD player a few year ago I wanted a marinized unit. What I found is that one of the big differences is that the circuit boards are epoxy coated. I decided on the cheaper Jensen unit , installed inside away from spray ext. It lasted maybe 12 hrs. before getting so hot I thought it was going to melt the CD. Returned it to WM and exchanged for another, installed the new player checking the wiring ext. same thing. I returned the unit for the second time. Went to Circuit City and bought an inexpensive Pioneer unit. It even came with a remote that has seen a few good sprayings and has worked flawlessly. My theory is that the epoxy coating on the Jensen unit would not allow heat dissipation?
Bill,
billangiep is offline
post #23 of 32 Old 03-15-2008
Maine Sail's Avatar
I have tons..
I have tons of non marine grade stuff on my boat. My iPod, my stereo, the cabin speakers, the "imitation" Ultrasuede interior fabric ($14.00 per yard as opposed to $70.00), every pot, pan, dish, spoon, knife and fork, our pepper grinder, our sheets, pillows, faucets, pats organizer bins, PB Blaster, throw rugs, Varathane oil based polyurethane for my cabin sole on and on etc. etc.
There are however things I do have that are marine grade. USCG rated fuel line, seacocks, AWAB hose clamps, UL tinned marine grade wire, plotter, radar, standing rigging, sheets and lines, Sunbrella, Strataglass, Starboard (plastic lumber), exterior varnish, VHF antenna and VHF, EPIRB, USCG flares, on and on etc. etc..
I buy from Wal*Mart when ever I can and do my part to support the Chinese instead of my fellow Americans who take joy in ripping us off every day at West Marine with 600% margins on some items!!
The bottom line is that living on the ocean I do see stuff wear out at my house only slightly less than on the boat if it's in the barn, shed or out doors. In the house with heating and cooling systems I see NO rust or corrosion on my electronic components and I eventually do on the boat...
80% + humidity on the inside of my boat during the summer and 50% or bellow inside my house during the summer months and they are 100 yards apart.. The difference is the humidity control afforded by my HVAC system..
This is what the ocean does at my house!! Perhaps i should have purchased a marine grade drill press?
______
-Maine Sail / CS-36T
Maine Sail is offline
post #24 of 32 Old 03-15-2008
Halekai-
It's obvious from that photo that all of your tools are in sad state of neglect... I'm going to have to call the National Society for the Prevention of Cruelty to Tools and Equipment. They'll be over with a bucket full of brass bristle toothbrushes...
Not everything needs to be marinized... but it also depends on the boat too. On a Gunboat 62, with its high freeboard, and exceptionally dry ride and air conditioning... I'm pretty sure the 42" HDTV they have in the salon and the two stereo systems are off the shelf from Best Buy or Tweeter. On a Cape Dory 25 or Corsair 28, both of which are far smaller and wetter boats, the electronics inside the cabin would probably be much happier if they were marinized.
Anything related to the safety and operation of the boat, like the list Halekai has mentioned:
really should be "marine" grade.
sailingdog is offline
post #25 of 32 Old 03-15-2008
Señor Member
TrueBlue's Avatar
I also live on the coast, actually an island, with a salt water beach off our back yard on the Sakonnet. The back end of my garage is set up with a shop and crammed with tools - all subject to rust and corrosion from the sea air . . . but I won't allow it.
No offence halekai, but your drill press is a sorry sight. (g) Why haven't you coated all your steel tools with a rag dampened with light machine oil? At least spray WD40 over them, or what I use, Boeshield T-9.
True Blue . . .
sold the Nauticat
TrueBlue is offline
post #26 of 32 Old 03-15-2008
Owner, Green Bay Packers
That is NOT just a drill press. That's a corrosion test sample! Notice the bronze control piece on the table along with the fine wire test sample in the chuck? hal's on the case. Results appearing in a sailing mag, or not, in the fall. (g)
Wm. F. Buckley, Jr.
sailaway21 is offline
post #27 of 32 Old 03-15-2008
I think Sailaway's right... what you don't see it the three identical drill presses in the same room, one of which has been coated with WD40, one with light machine oil and one with Boeshield T9. Halekai is only showing the control unit.
post #28 of 32 Old 03-15-2008
Señor Member
TrueBlue's Avatar
Inquiring minds want to know - hal, which of the three test sample drill presses is shown in your photo, the one with oil, WD40 or Boeshield T-9, so we know which to avoid?
True Blue . . .
sold the Nauticat
TrueBlue is offline
post #29 of 32 Old 03-15-2008 Thread Starter
chucklesR's Avatar
Alright gentlemen, post pictures of your pristine drill presses or leave poor Hal alone.
Mine, at 5 years old, looks like Hal's but dustier because of the oil trapping the dust.
post #30 of 32 Old 03-15-2008
SaltwaterSuzi/CapnLarry
LarryandSusanMacDonald's Avatar
Thanks for cutting thru the hype Chuck. You are entirely correct. What is the value in paying 8 times the price for an item when it will only last twice as long? Especially for creature-feature type stuff? Now I don't skimp on the stuff that keeps me upright and afloat, but a maranized cd player? No thanks! A 38-dollar unit from Wally World works fine and I throw it away when it corrodes.
Couldn't agree more. I have two 20lb propane tanks I picked up at home depot for about $25. each. Had to replace them when they mandated that overflow device thingy - but compared to the $300. west marine wants for aluminum? Mine are just fine. The first set lasted 5 years, the second is going on six and they're just fine - I keep them in a custom box on the back deck. I'm sixty two years old. Do the math. $50 for 2 or $600 for 2 and they'll last ten years, easy. Let's see, I'd have to live to be 122. We're currently on the Chesapeake also, but have accumulated several years in Florida and the Bahamas.
I personally have a little salt encrustation but I'm planning on taking a shower someday.
Saltwater Suzi and Cap'n Larry
"A sailboat is a fickle mistress. You’ve got to buy her things. You’ve got to understand everything about her. What you don’t know she’ll use against you." -Captain Larry
LarryandSusanMacDonald is offline
Low-cost outfitting GoodOldBoat Good Old Boat 5 03-21-2013 08:38 AM
Marine Radios Overview Jim Sexton Seamanship Articles 0 09-30-1999 08:00 PM
Marine Radios Overview Jim Sexton Gear and Maintenance Articles 0 09-30-1999 08:00 PM
Marine Radios Overview Jim Sexton Her Sailnet Articles 0 09-30-1999 08:00 PM
