Fishfinder or depth sounder
i just bought a Raymarine ST60 tridata for my c-30. the current depth gauge is dead. i few weeks back there was a thread about depth gauges and one or two people mentioned getting a fishfinder instead. i was also planning on buying a handheld gps sometime this summer. looking in the sailnet store, there are color fishfinders w/gps for little more than the st-60 tridata. which would i be better off with. i'll be mostly sailing narragansett bay, block island and up to martha's vineyard. also, any fishfinder/gps that anyone could recommend.
The only problem with getting one of the Garmin/Lowrance/Hummingbird combination GPS chartplotter/fish finders is that the wind instruments won't be able to talk to them, and can't estimate true wind speed then. If you don't use electronic wind instruments... you're home free. :)
I prefer the Garmin units, since some of their models have all of the US coastal water charts pre-loaded and they seem to have the best user interface and software of the different brands. |
Another consideration might be if the fishfinder has a depth alarm that can be set at a particular depth. Our Raymarine does, and we use that feature all the time.
For me it's a fish finder
And I'm not big on fishing :p
When there is a need for knowing the depth, a depth sounder can do just that. And no more. A fish finder provides a whole range of info like the shape of the bottom and the make-up of the sea bed (rock, sand, etc). Many of the better ones have forward-looking sonar that is also very useful. And it can also see fish if that's of any value to you. Andre |
Hello,
If you are in the market for a GPS, AND you need a depth gauge, you are best off buying a combo GPS / fish finder. On my last boat I had a Lowrance 3.5" combo unit (M68 C / Smap or something like that) that I paid $400 for and worked great. It came with detailed charts for the entire US. For my current boat I bought a similar model with a bigger screen. I paid $600 or so for it. It has inputs and outputs so I could connect my DSC VHF to it. Barry |
I've bought a fishfinder for depth measurements and have been really happy with it... Mine is a simple hummingbird unit with tri-band sonar. It gets really accurate bottom readings and graphic display is easy to keep track of depth readings to use with charts... I wouldn't recommend combo units since if the unit fails you have none of the tools, individual units are better... Handheld GPS wise if you have a data cord input/output you can use e-charts on your computer or connect it to your VHF to get lang/long info on your VHF and send DSC signal with your location...
Quick tip: If you install the transducent to your rudder instead of the hull you will avoid another hole to create problems and can get readings wider than fixed installation. My transducent is installed on the back of the rudder and I can get readings of the wider area beneath the boat by turning the rudder left and right... |
I have a fishfinder, but I don't fish.
There are times when layers of floating plants will give you a false shallow depth reading. There are also times when the water is too deep for a reading. In both cases the fishfinder will show you what's going on. The fishfinder shows a graphical history of depth, so you can extrapolate from the reading you got a minute ago. The fish finder can also show soundings at multiple depths simultaneously, so you can see the plant layer as well as the true bottom. A simple display with just a number is nice, but I wouldn't want to be without the details that a fishfinder provides. And lastly, the fishfinder is fun when you have kids aboard. They love watching for fish. |
I wonder if a fishfinder was called sonar would more people want them ?
Another trick is to set the alarm for a known depth contour, like 10 metres or 30 feet or something that will stick out on a chart. Then you can follow the contour in fog knowing where you are not, if you follow, which can be quite helpful. For instance, if you find a nav aid that your DR tells you is near, and it's close to a known contour, you can be in fog at night and find it, and then literally get your bearings. I'm no Luddite who would turn down a chartplotter, but give me a paper chart, a fishfinder (tells me when I've hit "shelly bits" or some unusual charted bottom state) and a compass, and I can usually find my way to safety. |
One other problem that I had was how to mount the speed transducer. Garmin doesn't offer a thru hull transducer for my fishfinder. I solved this by building a small solid fiberglass "transom" and gluing it to the bottom with 4200 between the keel and rudder. |
| All times are GMT -4. The time now is 03:14 PM. |
SEO by vBSEO 3.6.1
