-   -   Cutting hose (http://www.sailnet.com/forums/gear-maintenance/41355-cutting-hose.html)
Sixbrothers 03-14-2008 05:04 PM
Cutting hose
I am installing all new sanitation hose. I will be using "Odorsafe" and "Shields". I was wondering if anybody had any advice on cutting this material.
Thanks
sailingdog 03-14-2008 05:31 PM
One of the best things for cutting hose is a tool I picked up at Sears. It's like a pair of scissors but has knife blade on one side with a plastic anvil on the other side..and opens and closes like scissors. If you're using 1.5" hose, it might be a bit big...but IIRC, the longer jawed one did okay.
Don't remember what the tool is called.
mazzy 03-14-2008 05:44 PM
It's the tool used for cutting sprinkler hose.
Mike
wchevron 03-14-2008 06:33 PM
it's a pvc tubing cutter. you can also get them at home depot, lowes, etc. in the plumbing dept.
SailorMitch 03-14-2008 07:16 PM
Hacksaw works in a pinch. I also have one of the cutters Dawg mentions and they also work well (until you bung up the cutting blade that is.)
Freesail99 03-14-2008 07:21 PM
I'll second the hacksaw. It is what I used to cut 1.5 inch hose in the winery.
Quickstep192 03-14-2008 08:37 PM
I use pruning shears, the bypass kind with the curved jaw. I find it doesn't deform the hose too much while cutting it.
Freesail99 03-14-2008 08:43 PM
Pruning shears to cut 1.5 inch hose ?
sailingdog 03-14-2008 09:16 PM
I've seen bypass pruners go through a 1.5" branch, so a 1.5" hose should be doable.
brak 03-14-2008 09:17 PM
I use a sharp bladed knife (one of those with interchangeable blades) and metal shears for the reinforcing wire. That blade cuts through hose like scalpel.
