Old 05-16-2002
halyardz is on a distinguished road
Hillerange Alcohol Stove Fittings
Here''s an exciting topic. I pulled the tank on my Hillerange alcohol stove to replace the hoses and shut-off valve. Anybody know a source for those materials? I''d probably go for a replacement if it weren''t so dang expensive and that the existing unit works fine.
Old 09-11-2007
Rodz47 is on a distinguished road
I dug out the old post as there were no answer to the question. Does anyone know what type of hoses should be used for alcohol/kerosene connection from the tank to the stove if the system is of pressure type?
What kind of fuel should be used in this system? Kerosene or ???
Old 09-12-2007
bsfree's Avatar
bsfree is on a distinguished road
I used to have the same stove. I had a new fuel line made up as the fittings at either end need to be done properly to be safe from leaks. If you're doing it yourself then get proper fuel line hose that can withstand at least 30# of pressure as the tank should be pumped to approx 10-15# if I remember correctly. The fuel you use is denatured alcohol.
I know stoves are expensive, I replaced my pressurized one with an Origo, but while I like the alcohol method I feel much safer with the non pressurized design.
If you don't need an oven then the Origo 3000 is not too bad at around $300.
All the best
Old 09-12-2007
bsfree,
Thanks for your input. You are right that the tank should be pressurized approx 10-15psi. Do you remember by any chance what type or make of hose you used?? I visited a number of marine and automotive stores and nobody knows for sure what type of hose to use.
Old 09-13-2007
bsfree's Avatar
I had it made up for me at an marine/automotive store, was quite expensive. The hose they used was fuel line hose, I think the same hose that goes to the fuel pump on my diesel. It's quite thick walled and able to take the required pressure. Go to your local chandler and check out the hoses, take the fitting with you as you'll need to be sure to get the correct inside diameter hose. For what it's worth, before you spend any serious money on your pressurized stove, you should be comfortable that it's worth it. I wasted a couple of hundred on mine before giving up the ghost, and am really glad I now have a non pressurized unit (an Origo 6000 bought on ebay for 800). It's a pain that stoves (and fridges) are so expensive, but you'll only spend the money once, and get peace of mind and reliable service for many years.
All the best
Old 09-13-2007
rheaton is on a distinguished road
Folks, I was able to find parts for my alcohol stove from http://www.packstoves.com/. There customer service folks were very nice to work with.
Good luck to you.
Old 09-13-2007
TrueBlue's Avatar
Señor Member
TrueBlue is a jewel in the rough TrueBlue is a jewel in the rough TrueBlue is a jewel in the rough
Whenever my prior boat's Kenyon pressurized alcohol stove required replacement parts, I found them either from the mfgr, or at a local marine store with a consignment program.
Many boaters choose to offer their old stove and ovens (some defective and used for parts) to consignment when replacing or upgrading. I bought used burners, hoses, valves and nozzles for small change.
True Blue . . .
sold the Nauticat
Old 09-14-2007
thanks guys, I tried all marine stores nearby and I was told that it will be very difficult to find any parts to the Hillrange alcohol pressurize stove. Nobody could tell me what type of hose I could use, even the guy who represents Seaward.
Old 11-27-2010
L124C's Avatar
L124C is on a distinguished road
Updated Hillerange repair info?
One of my burners on my Hillerange alcohol stove had a low flame, so I pulled it apart. Getting the needle valve back in proved problematic. I'm trying to contact some of the sources in this thread, but the last post was 2007. The email link to Packstove failed (I'm always skeptical when I still see AOL email addresses, though I know they are still around somewhere!). If anybody has updated info or has serviced these burners, please let me know. I'm not even sure what model the stove is. Cant find a model # anywhere. It's a good stove, so I'd like to fix it. If anyone is still looking for hose, I think that braided steel rienforced line in the bottom of the picture is the way to go. Wadda Ya think of my hi tech cook top holder upper? Pretty spiffy eh?
Hillerange Alcohol Stove Fittings-016.jpg   Hillerange Alcohol Stove Fittings-017.jpg
Old 11-28-2010
SJ34 is on a distinguished road
Hillerange is manufactured by SeawardProducts. They don't service the older stuff themselves anymore but they can tell you who does. Check them out at Seaward Products then follow the links to parts and service.
Hillerange/ marine stove Martindk Gear & Maintenance 8 03-13-2011 01:00 PM
alcohol stove KenD Gear & Maintenance 18 11-12-2009 07:04 PM
Perko alcohol stove -- help! grey99 Gear & Maintenance 7 10-06-2009 01:51 AM
which model alcohol stove? S2 MONOBOY Gear & Maintenance 1 01-28-2004 01:55 PM
Need info on Pearson 30 alcohol stove pilot2sailor Gear & Maintenance 3 01-08-2004 12:01 PM
