Old 03-17-2008
Mad Bavarian
BigNige is on a distinguished road
Chart Plotter antenna rail mounting kit?
I have now bought the Standard Horizon CP180, with external antenna.
The antenna comes with a mount for a flat surface. The base can be removed to mount flush, or there is a 1" / 14 TPI thread, see photo.
Can anyone suggest where I can get a rail mounting kit for the pushpit?
[PS Photo upload failed, 45KB!]
Old 03-17-2008
T34C's Avatar
Thanks Courtney.
T34C has a spectacular aura about T34C has a spectacular aura about T34C has a spectacular aura about
Where's the photo?
Maeven
Tartan 34C Yawl #282
Anything-sailing.com
Moderator
Old 03-17-2008
BigNige—
Any marine chandlery will have an rail mount for that. It is a standard antenna mount.
Old 03-17-2008
Maine Sail's Avatar
Hamilton's has them..
Hamilton Marine has these: Railfast Mount
$21.99
______
-Maine Sail / CS-36T
Old 03-17-2008
T34C's Avatar
Thanks Courtney.
West Marine has a number of options available from $14.95 - $69.95. They are pretty easy to find.
Maeven
Moderator
Old 03-17-2008
thekeip is on a distinguished road
This is the right tool for the right job all right, but watch out for a particularly nasty problem with them. The cable, usually a coax of some sort, exits the antenna and gets threaded into and through the mount. You've got to be EXTREMELY careful to allow the coax to rotate as you screw the antenna to the base or you'll have a major, major problem. You can and probably will twist the cable right out of the antenna. It makes very little difference what the device is, either, the Raymarine R120 GPS antenna is a good example, as is most any antenna with an integral coax exiting the botom of it.
Howard Keiper
Dea Quest
Berkeley
Old 03-17-2008
Mad Bavarian
Thanks for the replies, all sorted.
All About Charts Jim Sexton Learning to Sail Articles 0 11-28-2004 07:00 PM
All About Charts Jim Sexton Seamanship Articles 0 11-28-2004 07:00 PM
All About Charts Jim Sexton Her Sailnet Articles 0 11-28-2004 07:00 PM
Choosing and Installing an SSB Radio Sue & Larry Gear and Maintenance Articles 0 09-28-2000 08:00 PM
Choosing and Installing an SSB Radio Sue & Larry Cruising Articles 0 09-28-2000 08:00 PM
