Painting a 1994 Catalina 270 - $3500 strip and paint? - SailNet Community
post #1 of 12 Old 03-17-2008 Thread Starter
1994 Catalina 270
Does that sound high? What should I expect to pay. I currently have a few original coats (never stripped) but some are chipping all the way down to gelcoat.
It is being dry-docked right now in Bay Head/Pt. Pleasant, NJ. I remember hearing that I cannot do any work myself.
Any suggestions?
Thanks!
Trescool is offline
post #2 of 12 Old 03-17-2008
artbyjody's Avatar
I know when I had my boat in for a paint quote on my 80 Catalina 27 - they came back with $8K (hence why I did it myself)....but they only use awlgrip so, perhaps that explains most of the cost.
Questions to ask - what kind of paint, and warranty...and definitely check out paint jobs that they have done on other boats in their yard...
-- Jody
S/V "
1983, Barberis Show 38! or
artbyjody is offline
post #3 of 12 Old 03-17-2008
sailortjk1's Avatar
Are we comparing the same thing.
Sounds like Jody is talking about topsides and trescool is talking about bottom paint.
Bottom job is something you should be able to takle yourself and save a ton of money. The hard part is stripping off the old stuff and that is where a lot of labor bills will come from. Nothing cheap about owning a boat.
Courtney is My Hero
sailortjk1 is offline
post #4 of 12 Old 03-17-2008
My yard charges $1200 to haul out and paint the bottom of my 270 with 2 coats & a third coat at the waterline using Petit Trinidad. I've been told that the cost of stripping can double or triple the cost but I've not had to go there yet.
capttb is offline
post #5 of 12 Old 03-17-2008
artbyjody's Avatar
You are probably right - in which case I paid $550 for pressure washing and adding a coat of ablative...(not including cost of haul out)...Have them strip /sand - you can roll the paint yourself...its kinda simple work to roll the stuff on...
-- Jody
S/V "
post #6 of 12 Old 03-17-2008 Thread Starter
1994 Catalina 270
Yes, it is for a bottom paint job.
I thought there were EPA legal-restrictions on stripping and/or painting your own boat... or am I wrong about that?
Trescool is offline
post #7 of 12 Old 03-17-2008
artbyjody's Avatar
There are processes that have to be adhered to - but nothing EPA related prevents one from doing it ones-self... The boatyard can give the boatyard rules that you must adhere to (and that they will enforce)... but most DIY yards or yards that allow self-work....
Usually entails a drop cloth under the entire area, plastic sheeting sealed to the ground around the entire boat to create a shield, and use of sanding tools that allow attachment to vacuum...Safety wise - the proper masks - and some yards may require special air masks for breathing as the bottom paint is toxic in general but sanding creates very small micro bits in the air...If sanding by hand then sometimes those rules are relaxed to just the special types of masks that have very fine filters...
The painting - drop cloth underneath....open area...
Sums it up in a nutshell...
-- Jody
S/V "
post #8 of 12 Old 03-17-2008
Trescool, a question I have delt with recently. You can expect to pay approximately $125.00/foot. Get really clear what you are getting for your money. stripping (inspect it), bottom coat (barrier paint matters), ablative (multi season or annual, annual build up thick fast *this is almost a direct quote from an old salt *). Of course the more specific you get, the more adders you have. This is our first boat and we still have coin in our pockets and dew in our eyes. Hope this helps, good luck.
Flatfoot
flatfoot is offline
post #9 of 12 Old 03-17-2008
By annual, I think flatfoot is talking about hard epoxy paints... rather than ablatives, which do not build up.
sailingdog is offline
post #10 of 12 Old 03-17-2008
Sea Slacker
A guy at my last marina did the same job on my Beneteau 285 for $1000, including materials. This was by far the best bottom job any of my boats got (including properly epoxying the keel). The thing is - he really worked for the sake of the high quality job, he likes doing that stuff, beleive it or not.
That said, yards are going to differ and the bigger the yard and the more proud if its "clean marina" designation it is - the more expensive this job will get. It certainly can go over $100 a foot,though I think less is still reasonable if you poke around.
As far as EPA is concerned - you have to have a tarp under your boat while stripping, control the run-off and have a vacuum based sander (though sometimes I notice people, including yard personnel, run the vacuum but not really connect it to the sander and don't have an effective hood on it Oh well )
brak is offline
How much does a typical bottom paint job cost? venturousviking Gear & Maintenance 49 10-21-2010 06:02 PM
How to Paint Your Own Deck Don Casey Gear and Maintenance Articles 0 02-04-2002 08:00 PM
