03-17-2008
This is one case where you can use the insulation foam sold at Home Depot etc.... pop the sink out - and add a 1/2 " - 1" of foam insulation to the sink underside...however - it is probably not just condensation from the sink but the cabinet in general as well... in which case - insulate the reefer, or add a cutout in the door under the sink or one of the cabinet sides for ventilation....
-- Jody
S/V " To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. " - 1983, Barberis Show 38! or To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
