Old 03-17-2008
GBurton is on a distinguished road
Mold west epoxy with poly vinyl sandwich wrap?
Will this work? Its a "saran wrap" type material. I dont want the west to stick to it.
Thanks for any help
Old 03-17-2008
Freesail99's Avatar
Freesail99 will become famous soon enough
Wax paper works well.
S/V Scheherazade
Old 03-17-2008
bogdog is on a distinguished road
aluminum foil works too and it holds a shape better. Beware, it is almost impossible to get it off after. So you will have permit "shinny" what ever.
Old 03-17-2008
artbyjody's Avatar
artbyjody is just really nice artbyjody is just really nice artbyjody is just really nice artbyjody is just really nice
Send a message via AIM to artbyjody Send a message via Yahoo to artbyjody
Also depending on the amount of surface area of the mold - one DIY trick is to use the cooking non-stick spray....
-- Jody
S/V "
1983, Barberis Show 38! or
Old 03-17-2008
Quickstep192 is on a distinguished road
I've used saran wrap several times to prevent epoxy from sticking; you just gotta make sure it doesn't tear or get a hole if you're clamping. I've also used that thin clear packing tape with good success.
Old 03-17-2008
SailorMitch's Avatar
Senior Moment
SailorMitch will become famous soon enough
I've used regular plastic wrap, but think Saran wrap would work as well to keep the epoxy from sticking.
SailorMitch
Sailing winged keels since 1989.
1.20.09 Bush's last day the end of an error !! Hopefully we still have a constitution and economy left by then.
"Compassion and tolerance are not a sign of weakness, but a sign of strength." The Dalai Lama
good planets are hard to find-- a song by steve forbert
I have but one lamp by which my feet are guided, and that is the lamp of experience. I know no way of judging the future but by the past.-- Patrick Henry.
Old 03-17-2008
Saran or equivalent should be OK with epoxy; but I remember having no luck with Saran with polyester, it dissolved.
Wax paper is better but doesn't take to a compound curve as well. If you're clamping I'd go with wax paper.
As a stronger alternative go for a heavier plastic film like vapor barrier.
1984 Fast/Nicholson 345
Curious about the West Epoxy System BigAssHam Sailboat Design and Construction 14 11-22-2007 09:48 PM
Key West, A Sailing Destination John Kretschmer Cruising Articles 0 09-27-2001 08:00 PM
Is Vinyl Antifoul better over Epoxy Barrier Coat pds Gear & Maintenance 3 08-27-2001 12:27 PM
Paint and West System Epoxy Marktesno Gear & Maintenance 2 03-31-2001 10:19 AM
