03-19-2008
I removed a Michigan Wheel 12 x 6 fixed two-blade from my 7/8" shaft attached to a rebuilt-in-2005 Atomic 4. The boat is a Viking 33, about 10,000 lbs. The new prop was a Gori 11 x 8 two-blade folder that had spent four seasons on a C&C 35, also with a 7/8" shaft and an Atomic 4. I cleaned it and used the right type of Lock-Tite on the allen key bolts and I keep it lubricated in spring and fall. I do not otherwise coat it, but I do use a donut-style zinc on the shaft. I have never seen much fouling on it, nothing a Scotch-brite pad and some Brasso hasn't fixed.
Sorry to be the happy customer, but the Gori has performed exceptionally well for me. I bought it primarily to reduce drag while sailing (although I don't race, I like to cruise like I do), and in this it succeeded entirely: I figured I have gained approximately 0.4-0.5 of a knot in speed with similar sail sets and wind speeds when compared to the days of the fixed prop.
A few comments:
Any folding prop is primarily designed to be slippery, not to drive the boat when motoring to perfection. This is why I'm installing a four-bladed feathering prop on my steel cruiser: the application is different. With the two-bladed Gori, I find I push the engine about 100 RPM more to get the same speed in flat water than with the fixed blade. On the other hand, cavitation at top speed is reduced, probably due to the squared-off blade tips.
Shifting is tricky because you have to go to neutral and then GUN the engine in reverse to deploy the blades. This adds about two seconds to this maneuver. Lucky I dock this boat in neutral as much as possible.
Prop walk is somewhat less. I don't know why.
A notable difference: My "dead slow" speed with a fixed blade on the direct-drive A4 was about 2.5 knots, which is why I docked in neutral, just aiming and coasting. With the Gori, dead slow pushes me at 1.7 knots SOG, which is much better for docking, as I can stay in forward closer to the dock in case I need to rectify errors.
Normally, I motor out just to get head to wind at five knots or less. The Gori pushes the boat fine here, but as with any folder or feathering prop, it's when you switch off that you notice the difference. This boat is now being raced by its "foster parent", and she loves it.
Your mileage, evidently, may vary. It cost me $300 and so far, it's provided that in enhanced sailing experiences.
