Horsepower to Displacement? - SailNet Community
post #1 of 33 Old 03-18-2008 Thread Starter
We're about to repower our 31 foot Pacific Seacraft Mariah. Most likely with a Yanmar, I'm just not sure about which model.
How many HP would you suggest for a 16,000 pound boat? The current engine is only 18hp. Do you think 21HP would suffice, or would you jump to 27?
The boat is new to us, I didn't get the chance to evaluate the 18.
Thanks!
dhornsey is offline
post #2 of 33 Old 03-18-2008
blue collar cruiser
soulesailor's Avatar
If you use your engine to get in and out of tight spots like marinas, docks, crowded mooring fields, etc. or use it to get home after the wind dies than 21hp is plenty. If you rely on it in bad weather when you no longer wish to sail than you might want more horsepower.
who is staring at the sea is already sailing a little
soulesailor is offline
post #3 of 33 Old 03-18-2008
Moderator
Jeff_H's Avatar
I have a 10,500 lb 38 footer, and have a 3GM30, which is advertized as a 27 hp, but for all practical purposes is a 24 hp Yanmar. Its fine in most conditions but in a short chop and strong current or headwind is about as little as I would want. The Mariah has more drag (so needs more in strong currents) but less windage (so is a little better in a strong headwind) than my boat would be.
Jeff_H is offline
post #4 of 33 Old 03-18-2008
buckeyesailor's Avatar
I just read a few days ago that you should have 2HP for every 1000 lbs. of displacement....so according to that, you need a 32 HP....
I'm a relative rookie, so It's not that I KNOW, but just passing on info I read that sounded good to me....Willy
buckeyesailor is offline
post #5 of 33 Old 03-18-2008
On the hard
CharlieCobra's Avatar
I guess I'm over powered with 14,000 and 50HP then. I sure needed ALL of it getting off a Lee shore in 50+ once though so I guess I'll keep it.
CharlieCobra is offline
post #6 of 33 Old 03-18-2008
Sailor
Plumper's Avatar
Current shouldn't have any effect on engine horse power. If the water is moving (current) then you simply have to have a boat that goes faster than the current. The limitation will be hull speed unless your engine won't drive the boat at hull speed.
Headwinds have a huge effect.
I have a 14,000 lb boat with a 2QM20 (20HP) and it is fine. I need to have a small bit of main up and motorsail when the wind is over 40 knots or I barely make any way to windward (unless I just sail). I heard that the traditional rule of thumb is about 3 HP per ton but most modern boats have more because they motor more often in bad weather than in the past.
There is a tide in the affairs of men,
Which, taken at the flood, leads on to fortune;
Omitted, all the voyage of their life
Is bound in shallows and in miseries.
Shakespeare, Julius Caesar IV, iii, 217
Plumper is offline
post #7 of 33 Old 03-18-2008
CharlieCobra, While shopping for boats I ALWAYS look for more HP than is normally available. I'm sure there are occasions where 200 HP would come in handy.....nothing worse than seeing a dock coming at you faster than you can backpaddle!
Willy
post #8 of 33 Old 03-18-2008
Moderator
Jeff_H's Avatar
Plumper, now that I think about it you are precisely right in the case of the Mariah 31 with her full displacement hull.
In the case of my boat with its semi-displacement hull, the higher hp results in speeds over theorical hull speed.
Jeff_H is offline
post #9 of 33 Old 03-18-2008
On the hard
Willy
In this case it was a twenty foot tall breakwater. It was so bad, the ferry couldn't get more than 200' off the dock and went back. We were looking for the hole and had gone around the point downwind. It took a bit but we motored back out until we found it and surfed through into the marina.
post #10 of 33 Old 03-18-2008
A 35 hp Volvo moves my 11 ton long keeler reasonably well.
Rockter is offline
displacement for a couples cruising boat witzgall Boat Review and Purchase Forum 11 05-23-2008 06:09 PM
Alberg 30; horsepower? greencaptn Boat Review and Purchase Forum 3 01-31-2007 10:25 AM
boat check - to Jeff H and others maiden Boat Review and Purchase Forum 21 12-05-2006 02:55 AM
Multihull displacement RunawaySkeleton Boat Review and Purchase Forum 1 11-06-2006 10:43 AM
Quick displacement question... kclaybrook General Discussion (sailing related) 19 07-13-2006 08:30 PM
