Rig tuning - Page 2 - SailNet Community
post #11 of 13 Old 03-21-2008
artbyjody's Avatar
When I hired "rigging experts" - the one thing I learned was that you do it manually and if it feels tight enough - in other words not to much slop - just enough hand / cable resistance to indicate some resistance ..probably good - check it after sailing if it feels sloppy - tighten a smidgen more... there really is no actual scientific procedure to the matter for most production boats...(that or I paid for a bunch of bad advice which has been known to happen)....
-- Jody
S/V "
1983, Barberis Show 38! or
artbyjody is offline
post #12 of 13 Old 03-21-2008
If you are going to use a halyard or tape to measure the distance from masthead to each side of the boat...make sure the mast is centered! Measure from the mast base to each side of the boat to see that there are no anomolies in construction or mast placement!
xort is offline
post #13 of 13 Old 03-21-2008
jimmyb116's Avatar
Also if you are measuring side to side make sure it is to a point equal distance from the bow, i was measuring to the chain plates only to find they were approx 2" off from each other ? bad build quality i guess.
Sailing one day at a time
jimmyb116 is offline
Ketch vs Sloop? bobmcd Boat Review and Purchase Forum 45 04-25-2017 01:37 PM
Sloop, Cutter or Ketch jsgsail Boat Review and Purchase Forum 17 12-26-2008 02:47 PM
My First Boat...Boat Term Question... Kacper General Discussion (sailing related) 38 09-23-2008 06:52 PM
Ketch/Yawl Handling svsymphony Seamanship & Navigation 19 07-05-2008 01:19 AM
Yawl Info Needed sailortonyb1 Boat Review and Purchase Forum 5 01-18-2006 04:51 AM
