Old 03-20-2008
joannemary is on a distinguished road
yanmar 2gm km2a tran
tran is slipping on full throttle can any body help is it oil and is it hydrolic oil
Old 03-20-2008
PBzeer's Avatar
Wandering Aimlessly
PBzeer has a spectacular aura about PBzeer has a spectacular aura about PBzeer has a spectacular aura about
The trans on my 2GM uses 30w non-detergent oil. Have you checked the level in your trans? When was it last changed?
John
Ontario 32 - Aria
Free, is the heart, that lives not, in fear.
Full, is the spirit, that thinks not, of falling.
True, is the soul, that hesitates not, to give.
Alive, is the one, that believes, in love.
JCP
- Website & Blog
Old 03-20-2008
2gmtran
just bought boat oil change not known but is it a hydrolic box?
Old 03-20-2008
JohnRPollard's Avatar
Moderator
In most sailboat installations I'm familiar with, the 2GM was coupled with a transmission that used the same oil as the engine.
Here's a helpful resource: Link
Old 03-20-2008
PBzeer's Avatar
Wandering Aimlessly
No, it is not hydraulic oil.
John
Ontario 32 - Aria
JCP
- Website & Blog
Old 03-21-2008
2gm tran
is it a cone box
Old 03-21-2008
querencia is on a distinguished road
Smile 2GM Transmission
I think that you are going to find that the cone is slipping and
needs to be replaced,When mine was going, I was able to hold the shift lever all the way forward while bringing the engine speed up slowly [ Assuming you have two separate levers ] and that seemed to solve the problem on a temporary basis until the wear of the cone got worse and the only solution was a repair, Yes, the transmission uses 30W oil just like the engine,it holds at the most maybe 8 ounces !!!
Ed
Old 03-21-2008
will the oil level cause problem. thanks for the info
Old 03-21-2008
PBzeer's Avatar
Wandering Aimlessly
Yes, improper oil level can be a problem.
John
Ontario 32 - Aria
JCP
- Website & Blog
Old 03-21-2008
Northeaster is on a distinguished road
There was a post, in Yanmarhelp.com, or Torresen Marine's forum, where a guys described how to take the trannie apart, and lap the cones with valve lapping (gritty) compound, so that the drive cones will catch better against the forward / reverse gears. I have read that it is a common problem, that they become glazed / slippery, and won't engage well. Some have said it should be done every few years.
Related question, I have exactly the same setup, and have read that normal engine oil is used in the trannie. Before I read this, however, I read in my yanmar manuel, to use a Dextron 3 type fluid, so I topped up with this type of fluid in there, for the last 20 hours of so, last year. Seemed to work the same.
Taking the trannie apart now, to lap the cones / inspect things.
Just wondering if I should put engine oil in next year, or Dextron 3 type.
Thoughts?
Yanmar 2GM or 2QM15...? marinesniper Gear & Maintenance 20 03-10-2012 12:47 AM
Yanmar 2GM zfactor Boat Review and Purchase Forum 5 06-08-2009 10:00 AM
Yanmar 2GM intermittent low power Northeaster Gear & Maintenance 21 07-31-2007 11:43 AM
Yanmar 2GM overheating Northeaster Gear & Maintenance 11 07-18-2007 03:07 PM
yanmar 2GM low cooling water volume?? Northeaster Gear & Maintenance 3 05-30-2007 11:02 PM
