- Quick Menu
03-20-2008
Offshore heaters-lp, diesel, solid fuel-opinions?
I want to put heaters in my Pearson 33 and Tartan 34 to extend the season away from the dock. They would mostly be used at anchor, but possibly underway some protection. There are a lot of different people using the boats. I have an alcohol stove in one and a CNG in the other, so no propane tanks. Engines are diesel. The solid fuel heaters seem like a possibility. Are they dangerous?
Wolfsong
Pearson 33 (1971)
Tartan 34-C (1977)
Tartan 37 (1978)
Lake Superior
03-20-2008
Sailor
Pacific Seacraft Crealock 31
03-20-2008
I would go with a propane heater for the following reasons:
Solid fuel and diesel heaters tend to be pretty smoky and tend to leave exhaust stains on anything over the stack. A solid fuel heater is also going to be the most difficult to fuel for extended periods of time and the messiest to clean up after. You do have to periodically remove the ashes from a solid fuel heater, which isn't the case with a propane or diesel heater. Solid fuel is also harder to keep dry on a boat, and not necessarily easily available at marinas when you're cruising.
—Captain Malcolm Reynolds, Serenity (slightly edited)
If you're new to the Sailnet Forums... please read this POST.
03-20-2008
A little less cheek
I have two propane heaters, portable types that run off those green bottles. The heaters I have are approved for indoor heating with oxygen sensors. Although nothing else on the boat is propane, well the BBQ, I carry two tanks and I have an adaptor to refill the green bottles.
Check them out OSH at about $100 each
Just checking in. Where ya'll keep'n the wimmin 'round here?
03-20-2008
The only problems with using the heaters that Ian is recommending are that they run the risk of CO poisoning or oxygen depletion and they create a lot of moisture inside the boat, which will lead to mold/mildew problems if not removed from the boat.
03-20-2008
Sailor
I have a Dickenson diesel stove in my boat. It is fantastic. It leaves no smoke stains anywhere and burns nice and clean. It keeps the entire boat (33') warm and toasty, like a wood stove in a cabin. It has extended our cruising season and is makes our boat a great place to kick back on a cold winter night. I love it.
It is gravity fed from a day tank that holds 6 gallons. It will run continuously for 7 or 8 days on a tank. I fill the tank from the fuel tanks via a little lift pump. I have never run it full on, the boat would get too warm. I don't often let it run at night when we are sleeping because I'm a bit funny that way. Most people do leave it run. They are very popular here in the PNW on real boats. You see them on liveaboards, fish boats, tugs and many others. I give mine a good clean every year or so. It is 30 years old and all original. That is good value!
There is a tide in the affairs of men,
Which, taken at the flood, leads on to fortune;
Omitted, all the voyage of their life
Is bound in shallows and in miseries.
Shakespeare, Julius Caesar IV, iii, 217
03-20-2008
Yeah and the sparks can also burn holes in sails and canvas. Just ask my buddy Seth whom you met at the Maine Boat Bulders show. There have been a few interesting "solid fuel issues" over the years that were repaired at his shop.
There is a reason, draft being one, the chimney on the house is far taller than everything else....
If I were to seriously consider a heater, oh wait I have one of those POS Force 10 heaters, I mean consider a real heater, I'd go Webasto or Espar the Dickinson's are nice too..
03-20-2008
Sailor
I forgot to mention, the Dickenson uses no power. Zero, zilch! It makes no noise, and has no moving parts. It really is unbelievable.
03-21-2008
Let me throw in one more thing about the Dickenson heaters (I have the propane fireplace): Their support is fantastic. I emailed a question about wiring (my fan isn't working) Saturday night and got a very informative reply on Sunday morning, including troubleshooting steps, a wiring diagram, and replacement part numbers if needed.
03-21-2008
I fitted an Eberspacher 3 kW, back in 1993.
It does not dry the boat as well as a solid fuel heater, but it is reliable, and easy to start and use.
Back in 1997 it filled the cabin with a thin smoke when I was asleep. I wrote to the manufacturer, got no reply, then wrote again. They sent me a spare glow plug. It has not happened since.
I never run it at night after that. Never.
So, all in, it has been a useful unit. It is virtual life support for end-of-season sailing in the canal system.
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
