03-24-2008
John, I think most of the industry will tell you tht you must run a new cable but others will tell you they've made do with splices. You can always TRY a splice, if it doesn't work you buy a new cable. If this is coax cable? Have two new "male" fittings crimped on the cable ends and use a dual-female connector to join them. Not knowing that cable you have or what fittings they use...I'd guess this is $25-30 in fittings alone, from a prime source. Plus the correct crimping tool, the one from the auto parts store won't do it correctly. And then if the splice works, seal it with butyl (self-vulcanizing) tape.
It *is* possible to splice a coax cable with just a soldering gun, but that creates an "impedance bump" in the cable which may affect the signals. I wouldn't recommend it except as a "get home" repair but again, some folks swear by it. Either by crossing over the center core to the hacket (and vice versa) and using teflon tape to warp and insulate then, rebuilding the core separation (and finishing with butyl tape) or by literally joining the center wire, rebuilding the gap with teflon tape, and resoldering the braid over that. And again, finishing with butyl.
I'll get flack for even having mentioned it--just remember I'm not recommending you do it that way! A proper splice, or a new cable, would be the way to go.
