PSS Shaft Seal Question - Page 2 - SailNet Community
post #11 of 17 Old 03-23-2008 Thread Starter
danielgoldberg's Avatar
Originally Posted by VikingSailor View Post
Dan,
You do know about "Burping" the PSS when the barb is capped off?
Paul
Thanks Paul, yes I do. They say you need to burp it only when the boat first goes in the water, but frankly, I'm paranoid, so I burp it periodically.
Dan Goldberg
danielgoldberg is offline
post #12 of 17 Old 03-23-2008
I think you only need to burp it when it first goes in the water, since you need to get rid of all the air trapped in the seal, so that the water can lubricate the shaft.
sailingdog is offline
post #13 of 17 Old 03-23-2008
the pointy end is the bow
erps's Avatar
I used to have to burp the one on my Catalina after diving on it to scrub the bottom too.
I also compared the new and old bellows, the old one was permanently compressed by about 5/8" so it was not putting as much force on the seal as it was supposed to. They recommend replacing bellows every 7-9 years if I remember correctly.
That sounds like good advice. I think I'll get one ordered up for our next haul out.
Ray
S.V. Nikko
1983 Fraser 41
La Conner, WA
erps is offline
post #14 of 17 Old 03-23-2008
Maine Sail's Avatar
Originally Posted by erps View Post
What's the issue then? I figured they were concerned about the set screws backing out, the collar slipping and the boat sinking.
If you look closely at the ends of the set screws they have a sharpened tip much like that of a leather punch. This tip is a one time use. They are sharp enough to be screwed into a bronze or stainless shaft once but after that they become dull and won't hold nearly as well. My guess is you could re use them maybe once but I would not try for a third.. When and if you replace them do not replace the with the "cone" or "pointed tip" type and make sure the ends look the same as the ones that came out.. PSS will sometimes send them out to you if you just pay the shipping..
There are different types of set screws but PSS uses the cup style:
Dan,
With $4.00 worth of vent hose, $3.00 worth of hose clamps is all you'd need to vent that seal! Run the hose well above the heeled waterline, it should take less than a half hours time, even if if your really slow, and you'll never need to burp again!! I can't for the life of me understand why people "cap these off"??
P.S. The manufacturer added the vent for a reason why not plumb it in? If your getting carbon it may be because, on occasion, it becomes air bound, runs dry, and gets too hot. ALL PSS seals now ship with the hose barb because they had too many complaints of them running dry EVEN and slow speeds...
______
-Maine Sail / CS-36T
Maine Sail is offline
post #15 of 17 Old 03-24-2008
erps's Avatar
Thanks for the tip on the set screws. I noticed the tips and the little circles they cut into the shaft. It's easier for me to remember something if I know the "why" behind a particular requirement.
Ray
S.V. Nikko
1983 Fraser 41
La Conner, WA
erps is offline
post #16 of 17 Old 03-24-2008 Thread Starter
Originally Posted by halekai36 View Post
Dan,
I contacted the company about that when we bought it for our current boat because I couldn't find one without the high speed cooling fitting (they used to sell two versions). They said they now produce all of them for the high speed fittings because it was cheaper for them to make one type of stator instead of two. It had nothing to do with complaints about slower boats getting airbound, or at least that's the story I got from them. Also, I believe the "proper" installation is to run the hose to another water source so that water gets forced into the assembly for cooling purposes. I'm almost positive that that's how I've seen them installed on power boats. Of course I could be wrong.
I guess I capped it because I'd prefer to have less openings in the boat then more. But I hear your point, and maybe I'll change it. I'm actually going to the yard today, so I'll spend a little time on that (and my SSB installation!).
Thanks.
Dan Goldberg
post #17 of 17 Old 03-24-2008 Thread Starter
Just spoke with PYI
They say the crystals or shards that I saw in fact was salt (thanks erps). They also say it's no big deal at all, a relatively common occurrence and that I should just take some 600 wet/dry sandpaper folded over and rub it between the carbon and stainless stators a few times.
Also, as to plugging or plumbing the vent hose, they confirmed that plugging it is totally fine provided that you burp upon launching.
So all in all, for a change, this "problem" is not a problem at all and will cost nothing to "fix."
Dan Goldberg
PSS shaft seal Windborn Gear & Maintenance 26 02-01-2009 10:10 PM
Jeanneau Sun Kiss 47 - shaft seal freeheel999 Gear & Maintenance 0 11-21-2007 04:02 PM
Shaft seal Edo Kazumichi Gear & Maintenance 9 11-23-2006 11:03 AM
Packless Shaft Seal (PSS) bkdehuff General Discussion (sailing related) 4 04-20-2004 05:41 PM
The Stuffing Box and Stern Tube Tom Wood Gear and Maintenance Articles 0 04-27-1999 08:00 PM
