Old 03-24-2008
johnr
jr438234606 is on a distinguished road
Roller Furling Line
Is there anything special about the line used on typical roller furlings? I've seen lots of recommendations for the various applications of different types of lines, but nothing on the roller furling application.
Old 03-24-2008
Stillraining's Avatar
Handsome devil
Stillraining is a jewel in the rough Stillraining is a jewel in the rough Stillraining is a jewel in the rough
Not that Im aware of...Mine is plane 3/8 double braid...Racers might use a low stretch
Old 03-24-2008
FrankLanger is on a distinguished road
I think for most regular sailing, it's mainly important to get the right diameter/thickness of line--to thin and it's hard on the hands and maybe too weak in a blow; too thick and it won't fit into the drum properly when rolled up. Also important to make sure it's run correctly--ie. 90 degrees from the drum to the deck fitting, then back to the cockpit with a ratchet cam or cleat to tie it off well so it doesn't come undone unexpectedly.
Frank.
Old 03-24-2008
I'd rather be sailing
labatt will become famous soon enough
Make sure it's not too slippery. The line shipped with the new Harken Mk IV furlers, for example, sucks. It feels like the nylon stuff you buy at the hardware store. It's tough on the hands in a blow.
s/v "Pelican" Passport 40 #076- Finished Cruising - for the moment -
"Don't dream your life, live your dream" - Bob Bitchin'
"I'll see it when I believe it" - Me
Old 03-24-2008
teshannon's Avatar
teshannon has a spectacular aura about teshannon has a spectacular aura about teshannon has a spectacular aura about
I would recommend using Trophy Braid. It has a soft fuzzy feel and is easy to grip, hence easy on the hands.
Old 03-25-2008
BarryL's Avatar
BarryL is on a distinguished road
Hello,
What is the furler? My boat came with an older Hood unit that was originally a line drive and was then converted to single line. The line must have the core stripped so that it fits on the drum.
Barry
Barry Lenoble
Day To Remember, 1986 O'day 35
Mt. Sinai, NY
Old 03-25-2008
Barry-
Most furlers will hold sufficient line that the core need not be stripped, if you're using the proper size line.
Originally Posted by BarryL View Post
Hello,
Barry
Old 03-25-2008
BarryL's Avatar
Hood Furlers
From the Hood web site:
November Tech Tip. I up graded my LD system
to a SL what line do I use?
As LD (line drive) customer's consider the upgrade to the SL (single line) drive unit system, please note the difference in the furling line sizes. The LD furling line diameter is different than the SL line diameter. You can not use your old furling line on a new SL furler. The first third of the furling line for the SL system, must be de-cored going into the drum. We sell de-cored furling lines for all of the SL systems. It's a good tip to purchase a furling line when ordering a new SL upgrade. When you purchase from Hood Yacht Systems direct, you know it's going to be a quality line, factory de-cored and at a upgrade customer's discounted price.
Pompanette LLC.
Barry-
Barry Lenoble
Mt. Sinai, NY
Old 03-25-2008
djodenda's Avatar
djodenda will become famous soon enough djodenda will become famous soon enough
I have a Hood DL -> SL furler with the cored line. It was installed by the PO. I have already removed the old "bad" line so that I could reverse/replace it. Looks like I'm going to have to put it back on again!
David
1987 CS 36 Merlin "Kyrie"
Old 03-25-2008
Barry-
That's for one brand of furler. I have a Furlex, and it doesn't require the core to be stripped out. Either do most of the other brands I've seen.
How to make a furling line? MelSnyder Gear & Maintenance 5 06-22-2007 08:13 AM
Roller Furling Lay Up Tom Wood Gear and Maintenance Articles 0 10-21-2003 08:00 PM
Hold That Line Tom Wood Gear and Maintenance Articles 0 10-03-2002 08:00 PM
Using Winches Safely Sue & Larry Gear and Maintenance Articles 0 08-18-2002 08:00 PM
Installing Roller Furling Sue & Larry Gear and Maintenance Articles 0 08-09-2002 08:00 PM
