Old 03-24-2008
pegasus1457's Avatar
Arf!
pegasus1457 is on a distinguished road
installing waste tubing
I am in the middle of replacing my old (stinky ) toilet waste tubing with new and expensive odor-free variety.
I am having a problem getting the new stuff installed. It came in a 3 ft diameter coil, and the shape has been memorized by the plastic. The pieces I have cut are really difficult to handle -- I have used a hot air gun to try to undo this memory and when the plastic softens a bit I can straighten it, but as soon as it cools it returns to the coiled shape.
The path that it has to follow is complicated and I have not been able to get it past more than the first bend.
Any ideas?
Thanks ---
Fluctuat nec mergitur
Old 03-24-2008
Freesail99's Avatar
Freesail99 will become famous soon enough
Very hot water helps get out the bends.
S/V Scheherazade
Old 03-24-2008
soulesailor's Avatar
blue collar cruiser
soulesailor is on a distinguished road
You're on the right path. You need more heat and more bending. I used a blowtorch to heat up my plastic, until it was almost too hot to touch. Be careful not to burn the hose or it will permanently deform. A careful touch is required and keep moving the heat around to the entire area you want to bend. When it is hot enough bend it the way you want it and keep it in that position until it cools, which isn't long. If you are going for a sharp curve you may need to overbend to allow for spring-back, like wood.
who is staring at the sea is already sailing a little
Old 03-24-2008
djodenda's Avatar
djodenda will become famous soon enough djodenda will become famous soon enough
Keep some water boiling on your stove, if you have one, and soak the end in the water for a few minutes before you try and push it on the fitting.
Using boiling water instead of a torch means that you won't damage/melt your hoses.
Patience and persistence is the answer.
I've seen "Hose Lube" at the chandlery, but it is expensive. No idea whether it is worth the cost or not.
David
1987 CS 36 Merlin "Kyrie"
Installing an anchor windlass GoodOldBoat Gear and Maintenance Articles 7 02-24-2011 10:22 PM
rubber tubing lost in engine crankcase nmerson@earthlink.net Gear & Maintenance 6 01-12-2008 02:00 PM
Installing an anchor windlass GoodOldBoat Gear and Maintenance Articles 1 08-26-2007 07:03 PM
Drilling SS tubing - installing ladder treads Nacci1 General Discussion (sailing related) 4 05-17-2006 11:54 PM
Installing Treadmaster Nonskid Sue & Larry Gear and Maintenance Articles 0 07-11-2004 08:00 PM
