Engine Removal - Page 2 - SailNet Community
post #11 of 11 Old 03-25-2008
Courtney the Dancer
jrd22's Avatar
Talking
If your boom extends well into the cockpit (I think the 31's does?) I would suspend a piece of 2 or 2 1/2" steel pipe below the boom running from the front of the companionway hatch to the back of the boom. Secure it with several loops of strong line at the front and back. Support the boom with halyards where the lines holding the pipe are. I would lift the engine with a good come-along, or better yet, a chain hoist. You will want to be guiding the engine as you lift it and being able to raise and lower it as needed will be a big help, especially when installing the new one. If you attach the come-along or chain hoist to the pipe with a short section of chain once you raise the engine up high enough you will be able to slide the engine out the companionway (push the chain on the pipe) Then swing the boom over to the dock to unhook. You should be able to raise the boom with the halyards if you need additional height to clear the lifelines, but secure the engine well before you tilt the boom. I would hook two halyards at the aft end of the pipe and one at the forward end. Should be a piece of cake, just like all boat projects .
I kind of like Erps idea for testing the whole rig prior to the actual job
Good luck, John
John
SV Laurie Anne
1988 Brewer 40 Pilothouse
jrd22 is offline
Runaway Diesel Engine Ben Hilke Gear and Maintenance Articles 0 07-19-2004 08:00 PM
Caring for the Cruising Outboard Doreen Gounard Gear and Maintenance Articles 0 04-22-2003 08:00 PM
Surveying a Diesel Engine Tom Wood Buying a Boat Articles 0 01-26-2003 07:00 PM
Surveying a Diesel Engine Tom Wood Gear and Maintenance Articles 0 01-26-2003 07:00 PM
Replacing the Diesel Engine Sue & Larry Gear and Maintenance Articles 0 06-12-2000 08:00 PM
