Boat smell - Page 13 - SailNet Community
 7Likes
post #121 of 158 Old 04-14-2008
artbyjody - even with this thing i will still smell trouble......i just can't stand the normal boat smells or the cleaners.
NALANI13 is offline
post #122 of 158 Old 04-14-2008 Thread Starter
Once known as Hartley18
Classic30's Avatar
Dock
Nalani, if you can't stand normal boat smells why are you even interested in boats??
I'd rather take a deep breath down below and inhale the woody (pun intended) aromas of teak and varnish and rotting sea-creatures(!) than try to breathe in any modern city anywhere in the world.
Classic30 is offline
post #123 of 158 Old 04-14-2008
I'm the FNG still...
Lancer28's Avatar
Have you tried using a air ionizer / ozone generator (there are about a dozen names for it)?
I had that smell in my boat, and using the generator a few hours a week got rid of it.
The model I use is the Air Zone XT-800 (google it or go to airzone.com, I think); you can save a lot of money if you feel like building your own.
Robert
I reject your reality and substitute my own.
Lancer28 is offline
post #124 of 158 Old 04-15-2008
We likewise installed two of the vents, intake over v-berth, exhaust over galley. It was a condition imposed by my wife on the purchase of our new boat 6 years ago. After the first season, I pulled the batteries and have since run them only on solar. While the boat has obviously lost her "new" smell, it hasn't been replaced by anything the slightest bit objectionable. Only regret is buying the white plastic ones rather than spending the difference for the stainless steel. After 6 seasons, the plastic has gone yellow and is beginning to crack. Soon as a motor dies I'll be more than ready to replace, despite the cost.
On the other hand, once you have odor problems it's not always that easy to get rid of all traces and often you end up trying to replace the offensive smell with something less so. Still, constant air movement can't hurt!
upanchor is offline
post #125 of 158 Old 04-19-2008
Future liveaboard
boat odor/moisture
I just read on another forum that DampRid is the same thing as the pool chemical used to increase water hardness, calcium chloride. Any thoughts on putting some of these chips into glass jars for absorbing moisture and odor in a boat environment?
SailMonkey is offline
post #126 of 158 Old 11-06-2008
Talking Bildge Buster and cabin air ozone generator
I have read many of the threads in this post that claim your boat may sink using an ozone generator. I have been using an ozone generator in my engine room, operates all the time even at the dock, and one in my main salon that only operates when it detects orders for nine years. The engine room ozone generator keeps bildge and holding tank odors away and the salon generator keeps things smelling fresh as a spring rain even right after cooking fish or heavy garlic dishes. The Bildge Buster is USCG approved for operating in areas where flash points are a problem and my hoses, plastic clamps, wire coverings, etc. are all in good shape. I have read that ozone can damage these items but, I haven't seen it and since mine runs 24/7/365 I can't imagine the levels it would take to damage something. All hoses are flexible with no cracks. My advice is to contact the manufacturer via email and ask them about it. Sign me off as "SCSeaside still floating".
SCSeaside is offline
post #127 of 158 Old 09-07-2011
TSL
Odor watch 24/7
Ozone generators work and work well. They attack the odors and other (rubber) components in your boat. Chlorine Dioxide also eliminates odors but does not harm rubber. It can be activated and left in the boat around the clock.
To eliminate boat smell, spend about $20 and see how it works. Odor Watch 24/7 is one such product. You can use it when the boat is stored without having to run power to the boat.
Chlorine Dioxide attacks mold as well as oxidizing odor. Odor watch 24/7 is low level Chlorine Dioxide so you can be in the boat when it is activated.
TSL is offline
post #128 of 158 Old 09-07-2011
aeventyr60's Avatar
Tonight's boat smell- In the **** pit having cocktails, smell of something burning, um nothing cooking, smells like plastic, smoke in the cabin, holy sh*t, WTF? AC shuts down, look round, switch off all the power, feel the plugs, a 15 AMP 220V plug has burned to a crisp...luckily the fuse inside eventually blew, other wise we'd be toast..a good nose for smells is a good thing!
"Your dreams minus your doubts equals your net worth"
Life is a short journey, filled with emptiness and pain. Get all the sailing and booty you can.
aeventyr60 is offline
post #129 of 158 Old 10-05-2011
Sailing to surf
Beersmith's Avatar
I'm convinced mine was the rotten wood providing the boat smell.
To date, I've removed nearly every piece of wood (rotten or not) and the boat smell is gone. I have all of the old wood in a storage unit, and it now smells like a boat.
the boat now smells like epoxy and paint
My boat rebuild/sailing blog:
Beersmith is offline
post #130 of 158 Old 10-05-2011
TSL
Beer smith is right on. However, you can treat the wood before it goes too far. Check out the CNN video showing mold treatment after the New Orleans floods. Boater Tech - Boat Smell Removal | Completely Eliminate Odors on Your Boat - Boater Tech
Click on CCN reports.
TSL is offline
Construction of a PVC (Divinycell) cored boat Giulietta Sailboat Design and Construction 8 10-19-2007 05:46 PM
Naming and Renaming Your Boat Sue & Larry Cruising Articles 0 12-15-2003 07:00 PM
Fine-Tuning the Autopilot, Part Two Dan Neri Gear and Maintenance Articles 0 10-13-2003 08:00 PM
Performing in Light Air Brian Hancock Learning to Sail Articles 0 01-15-2003 07:00 PM
The Balance of Hull and Sails Steve Colgate Learning to Sail Articles 0 05-25-2000 08:00 PM
