Boat smell - Page 16 - SailNet Community
 7Likes
post #151 of 158 Old 06-10-2013
Re: Boat smell
A small solar panel and a computer fan, hooked to the main battery, gives you the same thing as solar vents, at a much lower price
Brent Swain is offline
post #152 of 158 Old 06-10-2013
outbound's Avatar
Re: Boat smell
Sun light works well. Empty the boat completely ( and I mean completely). Turn things over so all sides get sunlight and ventilation for a few hours Wash every surface you can touch with fresh water and vinegar of your boat and hard surface articles. Put it all together and drop some bilge cleaner and fresh water ( or just fresh and simple green or like agent) in bilge with your pumps turned off. Go sailing to weather and bash and splash it around. Drain and no smell at all unless you went Mexican for dinner last night.
Under looked issue on many boats is adequate ventilation. Spec'd louvers in all lockers and contained spaces. Have four dorades so air is moving even when "locked up".
Also double plumped the heads of new boat for fresh and salt and went with the fancy no smell hoses. If salt used on passage then pump out then fill with fresh and pump out again. Different kind of bugs live in salt and they are smellier. Also better for the plumbing to use fresh.
s/v Hippocampus
Outbound 46
outbound is offline
post #153 of 158 Old 06-10-2013
asdf38's Avatar
Re: Boat smell
Unfortunately that means running power to the vent. The self-powered nature of the Nicro Vents is a nice thing. At least in my case I'd have no way to hide the wire as it ran across the headliner to a vent.
But yeah, otherwise that's a really nice way to go. Just size the fan to use much less than your predicted solar power.
This year I removed absolutely everything from the boat over winter including all cushions, life vests bags etc. Basically anything soft that might absorb smell to get it out of the boat and let it air out for the whole off season.
Oh and I replaced the head and all plumbing and fixed 8 deck leaks....I'm definitely hoping for a fresher smelling boat this year.
asdf38 is offline
post #154 of 158 Old 06-12-2013
bigdogandy's Avatar
Dock
Re: Boat smell
One of the things I've noticed is the smell that comes from the sink and lavatory drains - almost the same as an overripe holding tank but not as powerful......I close the seacocks when I leave the boat, and apparently there is enough living material in the water left in the drain line above the seacock that it generates some aroma as it dies / decays. I've been making it a habit to put a few drops of Odorlos in the drains after I close the seacocks and and it takes away that smell.
I still have the issue of constantly having 1-2" of water standing in the bilge and the funky smell that goes with that, though.
Andy
Key Largo
S/V Everlasting Moon
1981 Endeavour 32
Be joyful though you have considered all the facts.
- Wendell Berry
bigdogandy is offline
post #155 of 158 Old 06-12-2013
Asleep at the wheel
jimgo's Avatar
Re: Boat smell
Andy,
Can you fix whatever is causing the water to pool in the bilge? Have you tried leaving the floorboards open when you leave? Also, have you tried pouring diluted vinegar into the sink?
I've installed solar fans in two different boats, and have been VERY happy with the results on both. I used the Nicoro on my C25, and I've put 2 Sunforce fans in the Allmand. The Sunforce is about half the cost of the Nicoro. I called a very large, well-known marine supplier who happens to sell both brands and asked about thei return/complaint rate for both, and they said that they don't get a lot of complaints or returns for either one. Other than the thrill of cutting a 4.5" hole or two in your deck, the install is pretty straightforward and easy. The increased airflow really helps dry things out quite a bit.
- Jim
Home: Western Philly 'burbs
1980 Allmand 31
1975 Albacore 15
jimgo is offline
post #156 of 158 Old 06-12-2013
bigdogandy's Avatar
Dock
Re: Boat smell
Jimgo - good idea about leaving the floor hatvch open when I'm not on the boat - I'll try that. There's never a lot of water, and I try to make it a habit to dry out the bilge when I leave the boat on Sunday afternoon. The water in my bilge comes from condensation on the refrigerator box, the drips from the stuffing box, and a few odds and ends leaks that I'm chasing (I think I am gaining ground on those and just have a few pieces of hardware left to re-bed).
Andy
Key Largo
1981 Endeavour 32
- Wendell Berry
post #157 of 158 Old 06-14-2013
Dirt Free
boatpoker's Avatar
Re: Boat smell
Originally Posted by miatapaul View Post
What brand and model? Sounds interesting.
Sent from my ADR6425LVW using Tapatalk 4 Beta
Sure you can get it elsewhere but we got it here
Be the man Sharon thinks I am - wg
I can do that
- wg
Be the master of your own disaster - wg
If you're not laughing, you're not doing it right. - wg
if you can live with the consequences, go for it. - wg
I yam what I yam an' thats all that I yam. - Popeye
boatpoker is offline
post #158 of 158 Old 06-14-2013
Sabreman's Avatar
Re: Boat smell
Canberra Gel. We placed 2 containers in the boat over the winter and the smell is gone. We'll keep a continual supply open and airing. Even the Boss notice the lack of smell and thinks that it's amazing. And she's isn't impressed with anything! The gel attacks spores and is not a cover up. Amazing stuff. We're sold.
Sabre 38 "Victoria"
Sabreman is offline
Construction of a PVC (Divinycell) cored boat Giulietta Sailboat Design and Construction 8 10-19-2007 06:46 PM
Naming and Renaming Your Boat Sue & Larry Cruising Articles 0 12-15-2003 08:00 PM
Fine-Tuning the Autopilot, Part Two Dan Neri Gear and Maintenance Articles 0 10-13-2003 09:00 PM
Performing in Light Air Brian Hancock Learning to Sail Articles 0 01-15-2003 08:00 PM
The Balance of Hull and Sails Steve Colgate Learning to Sail Articles 0 05-25-2000 09:00 PM
