Old 03-24-2008
OLYMPICYACHTS is on a distinguished road
New Engine Suggestions
Any suggestions on how to run my turbo yanmar engine its first hours of life thanks alex
Old 03-24-2008
never convicted
KODAD is on a distinguished road
What does the owner's manual say?
"Don't gain the world and lose your soul, Wisdom is better than silver and gold"----Bob Marley
100T Master NC
Old 03-25-2008
Rockter will become famous soon enough
Just don't thrash it.
Give it time to warm up a little before working it.
When you come to a halt, and the motor goes to idle, give it about 60 seconds to cool the turbo a bit before shutting down.
Bloody turbos... bloody turbos.... never liked them.
Old 03-25-2008
Why in god's name did you get a turbo yanmar for a boat? IMHO, a boat has no real need for a turbo-equipped diesel and the extra expense and complexity of a turbo diesel will come and bite you on the backside. Rockter's point about letting the engine cool the turbo off for a bit is important.
Old 03-25-2008
jrd22's Avatar
Courtney the Dancer
In general, I run a new engine gently for the first couple of hours, keeping RPM no higher than about 50%. After that I run them a little harder than normal for 10-20 hours, you want to make sure the rings don't glaze the cylinder liners. I change the oil initially after a couple of hours, then I go the full recommended change interval. With a turbo, as Rockter points out, you need to let it idle a minute or two if you have been running it hard to let the oil cool the bearing on the hot side of the turbo, generally not a problem if you idle into your slip or mooring as most do. Turbo's are an added complication, but generally they provide cleaner exhaust, more power and are much more reliable than they used to be (thousands of hours normally). I would carry a spare though if extensively cruising offshore. Usually an easy job to replace one depending on access.
John
John
SV Laurie Anne
1988 Brewer 40 Pilothouse
Old 03-25-2008
timebandit's Avatar
timebandit is on a distinguished road
Stay away from synthetics untill you are sure that the engine is TOTALY broken in.
Runaway Diesel Engine Ben Hilke Gear and Maintenance Articles 0 07-19-2004 08:00 PM
Caring for the Cruising Outboard Doreen Gounard Gear and Maintenance Articles 0 04-22-2003 08:00 PM
Surveying a Diesel Engine Tom Wood Buying a Boat Articles 0 01-26-2003 07:00 PM
Surveying a Diesel Engine Tom Wood Gear and Maintenance Articles 0 01-26-2003 07:00 PM
Replacing the Diesel Engine Sue & Larry Gear and Maintenance Articles 0 06-12-2000 08:00 PM
