Blogs
User Name
Old 03-25-2008
Omatako's Avatar
Omatako Omatako is offline
Omatako is on a distinguished road
Tank volume measurement
I've been looking for a reasonably priced, easy-to-install tank measuring system.
Whilst it is difficult to categorise $800-odd as reasonably priced, this system looks like it's at least easy to install.
The Tank Tender - by Hart Systems, Inc.
Does anyone on the forum have any experience with these units? The blurb on the website says it can even be used to monitor black water tanks but unfortunately I don't want to take the blurb as my only reference .
Andre
Old 03-25-2008
trantor12020's Avatar
trantor12020 trantor12020 is online now
trantor12020 is on a distinguished road
Andre, did you tried this Marine Holding Tank Monitoring Systems - Ferriello Sales LLC
Same person that made Snake River products but has improve on it.
Ken
Ken
2002 Hunter 326, SV Millennium 2
1999 Macgregor 26X, SV Millennium
Old 03-25-2008
sander06 sander06 is offline
sander06 is on a distinguished road
The Tank Tender is a completely bullet-proof, reliable system. We had one on a boat for 10 years with no problems. You can't go wrong except for the fact their EXPENSIVE!!!!
Old 03-25-2008
sailingdog sailingdog is offline
sailingdog is a jewel in the roughsailingdog is a jewel in the roughsailingdog is a jewel in the rough
Tank Tenders make a lot of sense on larger boats, since the base unit can do up to four tanks. One of their units can handle 10 tanks, and they can handle diesel, water and waste tanks.
If you're new to the Sailnet Forums... please read this POST.
Old 03-25-2008
teshannon's Avatar
teshannon teshannon is offline
teshannon has a spectacular aura aboutteshannon has a spectacular aura aboutteshannon has a spectacular aura about
I installed a Tank Tender on my boat last year and love it. It monitors 4 tanks, 2 fuel and 2 water. Easy to install. The only hard part is calculating what each inch of tankage is worth since the tanks are all odd shaped. While they are a bit expensive, you make that up with the lower cost of installation if you do it yourself or pay the yard to do it. I started a thread an Tank Tender at the time so might search the forum for that thread. As someone said, bulletproof.
Old 03-25-2008
Rockter Rockter is offline
Rockter is on a distinguished road
$800 for an electrical air pump, four bits of tube and a pressure gauge.
Old 03-25-2008
teshannon's Avatar
The air pump on the Tank Tender is not electrical, it's manual. Absolutely no elkectrical connections. I agree it seems like a lot but other than dipping the tanks there is no simpler and reliable way of doing it that I know of. The hardware by the way is top quality.
Old 03-25-2008
camaraderie's Avatar
camaraderie camaraderie is offline
Moderator
camaraderie has a spectacular aura aboutcamaraderie has a spectacular aura aboutcamaraderie has a spectacular aura about
Ditto on the Tank tender recommendations. I can't justify the price either but I've had it on 2 boats and it works well.
Tayana 52 Ketch
Old 03-25-2008
Zanshin's Avatar
Zanshin Zanshin is online now
Zanshin is on a distinguished road
Do those with the Tank Tender have a list somewhere which translates the analogue reading to a %age full value - with different number for each tank? Or does the output read in liters/gallons left without having to do any further math?
Zanshin - 残心
Old 03-25-2008
Zanshin—
The Tank Tender readout has to be individually calibrated for each tank, since a lot is dependent on the tank's physical shape. A tank shaped like an inverted pyramid might read a quarter full when the height of liquid is at a quarter of it's height, but it would really be only a 1/10 or so full. If the tank were shaped like a pyramid, it might be half full, even though the liquid is only a 1/4 of the tank's height.
Display Modes
vB code is On
Replacing my fuel tank this Spring, and need your sage advice. ChicagoNewport27 Gear & Maintenance 12 06-04-2008 07:39 PM
Diesel Fuel Tank Woes...or Bonehead mistake of the season rperret Gear & Maintenance 9 10-07-2007 09:32 PM
Building a head tank Irwin32 Gear & Maintenance 6 11-05-2006 12:24 AM
'68 M34 Water Tank Fill Hose Question dancrosswis Morgan 0 04-01-2006 02:07 PM
Diesel Engine Woes Mark Matthews Gear and Maintenance Articles 0 09-19-2001 08:00 PM
SEO by vBSEO 3.0.0 RC8
(c) Sailnet 2000-2006
