Old 03-25-2008
kccollbran's Avatar
It's 5 O'clock somewhere
kccollbran is on a distinguished road
Cutlass Bearing Help
I need to have the cutlass bearing replaced on my boat, she has a 1" prop shaft. The bearing cost is about $120. The problem is, I'm about 1,400 miles away and can't be there to supervise or comment on the work. The surveyor said everything is very clean and shouldn't be anything but routine. There are no other problems with the shaft or packing glands. So just a ballpark figure, what should I expect to pay without getting hosed? The work is being done in La Paz, Mexico.
Old 03-25-2008
IslandRaider's Avatar
IslandRaider is on a distinguished road
well that depends on what is involved in getting the old one out ane the new one in.
In my case I had to disconnect the motor and slide it into the cabin, pull the prop and remove the shaft from inside the boat ( not an easy job but its done), in order for someone to give you an idea you need to tell us what type of boat you have an model
S/V Privateer
42' Morgan Custom
Old 03-25-2008
PBzeer's Avatar
Wandering Aimlessly
PBzeer has a spectacular aura about PBzeer has a spectacular aura about PBzeer has a spectacular aura about
Is the boat on the hard, or in the water? If in the water, then you'll have to pay to have it hauled. Most places will have an hydraulic tool that will push the bearing out of the strut, and off the shaft. Reverse, for putting in the new one. I watched them do a boat last summer, where they had to trim off part of the strut and then fabricate a die, to get the bearing out of the strut. So it's hard to give an easy answer.
John
Ontario 32 - Aria
Free, is the heart, that lives not, in fear.
Full, is the spirit, that thinks not, of falling.
True, is the soul, that hesitates not, to give.
Alive, is the one, that believes, in love.
JCP
- Website & Blog
Old 03-25-2008
kccollbran's Avatar
The boat is on the hard. Only the prop has to be removed, and everything is very clean. Is it a matter of a couple of hours labor and the part?
Old 03-25-2008
PBzeer's Avatar
Wandering Aimlessly
It should be. Doesn't mean it will be though. As long as they have no problem getting it out of the strut, it should be a simple job.
John
Ontario 32 - Aria
JCP
- Website & Blog
Old 03-25-2008
petegingras's Avatar
petegingras is on a distinguished road
the cutlass bearing done by a surveyer, i agree it should be simple. The cutlass bearing done by me on the 1976 27' Catalina with the original bearing took me three hours to locate a mallet and hammer the right size to force it out. Then i realized that an inverted hacksaw blade, if done carefully would do the trick, that way it was just 20-30 minutes with the saw, hammer, and flat-head screwdriver.
factor in the seista.
s/v Libertine
Hunter 44DS
PS 37 Cutlass Bearing waypt1 Pacific Seacraft 5 01-15-2008 03:03 PM
Repairing Cutlass Bearings Mark Matthews Gear and Maintenance Articles 0 05-07-2002 08:00 PM
Installing a Cutlass Bearing Mark Matthews Gear and Maintenance Articles 0 04-26-2002 08:00 PM
Loose Cutlass Bearing Sue & Larry Gear and Maintenance Articles 0 02-18-2002 07:00 PM
Cutlass Bearing Query SailNet Gear and Maintenance Articles 0 06-06-2001 08:00 PM
