Old 03-25-2008
johnr
jr438234606 is on a distinguished road
Line on Hood Seafurl 3250 roller furling
Hi All, I have an older Hood Seafurl 3250 roller furling. It's time to replace the line in the drum. Does anyone know the procedure for this? There is nothing in the manual I have that mentions anything about dealing with the line. I also can't find anythong on Hood's web site. I can see where the line goes into an eye on the drum, but I can't figure out how to get at it to remove it and attach a new one. I guess I could just start disassembling things until I eventually stumble upon what I have to take apart to get to it-- but jeezum what a backwards approach.
Old 03-25-2008
johnr
Follow-up: I discovered that the line feeds through the eye, makes a 90 degree turn, and exits the bottom of the drum through 1 of 4 small holes where it is fitted with a retainer. So no need to disassemble anything.
Old 03-25-2008
pigslo's Avatar
pigslo is on a distinguished road
I replaced mine with a slightly smaller diameter but stronger line so that it would wrap better around the drum and not jam.
pigslo
Old 03-25-2008
Freesail99's Avatar
Freesail99 will become famous soon enough
I also have a hood, and be interested in hearing what line everyone is using.
S/V Scheherazade
Old 03-26-2008
capttb is on a distinguished road
Usually I use Sta-Set or Sta-set X but any good double braid will do, I use 3/8 and core about a third of it to fit the drum. There are some flat lines now made for furling use but they are pretty pricey. They do sell line on this site.
Shop.Sailnet.com - sailing resources, shopping, sail, blogs 1
Hood SeaFurl 810 repair Rgarv Catalina 2 07-10-2007 10:41 AM
Getting Good Starts, Part Two Zack Leonard Racing Articles 0 01-15-2004 07:00 PM
Getting Good Starts, Part One Zack Leonard Racing Articles 0 12-18-2003 07:00 PM
Hold That Line Tom Wood Gear and Maintenance Articles 0 10-03-2002 08:00 PM
Using Winches Safely Sue & Larry Gear and Maintenance Articles 0 08-18-2002 08:00 PM
