Ice box drain tube - SailNet Community
post #1 of 5 Old 05-20-2002 Thread Starter
Ice box drain tube
The drain tube on my Catalina''s ice box seems clogged. The drain connection is in a very difficult location to get to. I used a long wire to try to break up the clog, no luck. Any ideas?
lgsailor52 is offline
post #2 of 5 Old 05-20-2002
Ice box drain tube
Try a small Plunger (like for a toilet) and try and create some vacuum by plunging the obstruction out
tsenator is offline
post #3 of 5 Old 05-21-2002
Ice box drain tube
Hello
A well installed drain is usualy a syphon tube to prevent the cold air to dissipate out. The tube is U-shaped and will in all probability prevent a small wire through it. Air pressure will work or a plunger. Sometime a "draino" product will help.
Joe
jhanay is offline
post #4 of 5 Old 05-21-2002
paulk's Avatar
Ice box drain tube
A slow drain also keeps your cold ice water in where it''s insulated, helping to keep things colder longer. Unless it''s totally stopped, you may want to keep it the way it is. If you do need to "blow it out", another idea might be to fill the box with water and let gravity do its thing.
paulk is offline
post #5 of 5 Old 05-22-2002
Ice box drain tube
I had the same problem on my boat. The connection at the bottom of the ice box was not accessable so I couldn''t take the whole thing off and clean it. I got a hose to barb connector from the local hardware store. The barb fit into the drain hose with the other end on a water hose. I fit the barbed end into the end of the drain, then blasted with full water pressure. I made sure to close the ice box so water wouldn''t spray every where. It worked fine.
Good Luck
Dave
davealves is offline
Universal m35 leak at drain plug sailingdeacon Gear & Maintenance 1 01-07-2005 11:21 AM
cockpit drain clog Loualfr Gear & Maintenance 4 05-28-2004 03:51 AM
leaking and loose rudder tube ndsailor Gear & Maintenance 0 08-30-2002 05:06 AM
morgan 30 stern tube cholberger Gear & Maintenance 0 08-21-2002 08:16 AM
Wire tube in mast loki Gear & Maintenance 3 03-26-2001 06:50 PM
