03-26-2008
Free-
Can you post a photo of the cockpit of your boat??? That would make it easier to see what you're talking about.
Mounting it on the bimini might be one option, and then you could always move the boom over using the traveler and mainsheet to keep it from shading the panel, when you're at anchor.
Mounting them on the side rails is also an option, but in general, only one of the two panels will be usable, since chances are good that one will be shaded when the other is in the sun. I have the panels on my boat setup that way...sort of.  They're actually mounted on rails that go between the ama and the cockpit.
