Old 03-28-2008
Freesail99's Avatar
Freesail99 will become famous soon enough
Originally Posted by GBurton View Post
Gym seal works well too
I know someone who used gym seal on every piece of wood inside his boat. It looked like a sheet of glass.
If your into high gloss, it can't be beat.
S/V Scheherazade
  #12
Old 03-28-2008
lbdavis's Avatar
lbdavis is on a distinguished road
squeak
I was hoping to get that squeaking sound from under my foot when i change direction.
  #13
Old 03-28-2008
camaraderie's Avatar
moderate?
Ever poured water on a gym floor?
If you want the LOOK but don't want to go flying on your butt...suggest you look into Ultimate Sole.
Online Store
  #14
Old 03-28-2008
artbyjody's Avatar
artbyjody is just really nice artbyjody is just really nice artbyjody is just really nice artbyjody is just really nice
Send a message via AIM to artbyjody Send a message via Yahoo to artbyjody
I look at sole.. nothing ultimate...when asked the difference of soul versus sole...I said depreciation of a "U".. I got shot ...
boat purchases now full of soul... or ballasted with lead..
I have lots of lead now...
G thanks...
-- Jody
S/V "
1983, Barberis Show 38! or
  #15
Old 03-30-2008
lbdavis's Avatar
not quite
Ok. Here is my cabin sole after I stripped it down:
And here it is after two oxalic bleachings:
The teak has gotten A LOT better, but the holly is still quite dark. Will I screw this veneer if I do a shot of TSP then more oxalic acid?
  #16
Old 04-08-2008
lbdavis's Avatar
finished product!
I'm done.
I gave it a weak TSP treatment and a third oxalic bleach. Then dry-sanded with a 320 grit and applied 8 thin coats of Minwax Clear Poly - lightly sanding with 320 in between each coat.
It looks a lot better than the original...
...but not quite as well as I had hoped. It is certainly a lighter tone and many of the stains didn't come out of the teak and much of the mold would not lift from the holly.
All in all, I'll take it. Thanks for everyone's help.
Cheers,
LB
  #17
Old 04-08-2008
NauticalFishwife is on a distinguished road
Send a message via AIM to NauticalFishwife
Wait a minute... are you talking cockpit? Why not use Teka A and B and lightly, very lightly sand. That takes oh so many stains out. And do you really want to put anything on it for the cockpit? You don't want to put anything on it that makes it slippery when wet! Why lose the natural grip of teak underfoot? Unless you mean the cabin sole. We did our cabin sole, veneer, teak and holly with "Professional MinWax"... you can get it at Home Depot, but you purchase it by the gallon. I tried Ultimate Sole on a small piece of cabin sole but it did not do well on my old previously oiled for years piece. And yes, I followed their directions! When you work with Teka A and B make sure you keep it wet while you work and use a 3m scrubby ... you will see an amazing difference.
  #18
Old 04-08-2008
lbdavis's Avatar
Oops. Yes, I did indeed open this thread with "cockpit" sole. It is indeed my cabin sole that I've been working on.
I don't think I'll be stripping down those 8 brand new coats for some Teka A,B, but I'll keep 'em in mind for the next job.
  #19
Old 04-08-2008
pigslo's Avatar
pigslo is on a distinguished road
It appears to me from your pictures that you still have old varnish on the wood. That ends up trapping the discoloration underneath. If you strip carefully to wood, the discoloration should wipe off with 1 bleaching.
pigslo
  #20
Old 04-09-2008
Shortman is on a distinguished road
Doubt Minwax
IMHO Minwax will afford minimal protection, use a product intended for cabin soles that are subject to high humidity, high wear, UV exposure through hatches & portlights.
Bleaching will also remove teak color so test finish spots first in case you want to put some color back.
You may post attachments
You may edit your posts
Port Hole Gaskets & Teak Veneer Windermere Gear & Maintenance 11 07-17-2007 09:16 PM
Teak Veneer nesailor Gear & Maintenance 3 01-06-2005 03:33 PM
bleaching teak prussell Gear & Maintenance 4 04-23-2004 06:20 AM
Varnishing Teak Veneer Stormer Gear & Maintenance 2 07-12-2003 03:45 AM
Diesel Stain in Teak Veneer vikinglady herSailNet 1 07-22-2001 09:35 PM
SEO by vBSEO 3.6.1
