Old 03-30-2008
aphil138 is on a distinguished road
Using a spinnaker pole instead of a whisker pole
To use a spinnaker pole in instead of an extendable whisker pole I need to come up with a compromised length. Most spinnaker pole recommended lengths are for the J dimension. Using a 130% headsail on roller furling, I am wonder whether the pole should be longer - say 1.3 times J. Of course I am not intending to JIB the pole - but if I had to, just use the dip method.
Thoughts?
alan
Old 03-30-2008
Sabreman's Avatar
Sabreman will become famous soon enough
We use a Forespar whisker pole. The adjustable length eliminates the need for precise measurements with respect to length.
North Sails has a very good description in the following link.
What Cruising Sailors Need to Know
Forespar Whisker Pole at Mauri Pro Sailing
Sabre 38 "Victoria"
Old 03-30-2008
JimsCAL's Avatar
JimsCAL is on a distinguished road
I have used my spinnaker pole as you suggest when racing jib-and-main or cruising. The fixed length is definitely an issue. Sometimes too short, and others too long.
Old 03-30-2008
Sabreman's Avatar
Sorry - I just realized that you want to size the spin pole, not the whisker pole. The spin pole should be 100% of the J per PHRF rules.
Sabre 38 "Victoria"
Old 03-30-2008
Vitesse473's Avatar
Wannabe Sailing Bum
Vitesse473 is on a distinguished road
What do you mean you won't jibe the pole? At some point you need to turn, thus you need to jibe. Dip poling is near impossible if you have a pole longer than J. Also consider how much extra weight you'll need to deal with at 1.3x J.
Additionally, just yesterday I was heading downwind wing on wing flying my 110%. Wind was at 12kts and rather flukey (common in SF Bay). The jib was not fully cooperating, so I considered (for a moment) using the spinnaker pole. I didn't feel like rigging the foreguy, so I opted out. However, the length of my pole (equal to J) would have worked just fine. I speculate even better had I been flying the 140%.
Old 03-30-2008
Plumper's Avatar
Sailor
Plumper is on a distinguished road
The reason a whisker pole varies in length is so that it can be used with different sized jibs. Just using the spin pole (or any fixed length pole would be somewhat limiting. The length of a whisker pole is not a function of J because it depends on the length of the foot of the jib and the height of the clew. If you want to pole out a jib and not use a spin, just trade the pole in. A whisker will work way better.
There is a tide in the affairs of men,
Which, taken at the flood, leads on to fortune;
Omitted, all the voyage of their life
Is bound in shallows and in miseries.
Shakespeare, Julius Caesar IV, iii, 217
Old 03-30-2008
Thoughts?
alan
You can use without problems a spi pole on a genoa. I do that all the time when wing on wing to balance the boat, specially if my son is at the helm..
Mine in the photo bellow is a 115% on a furler, and it works just fine. The pole serves only to stop the clew from "returning" to the boat and flapping the sail..sheet in / out as needed to keep the sail curvature, and rig the uphaul to support the weight of the pole, so it does not pull the sail down and deform it. In heavier winds, pull the pole down withth the downhaul to flaten the sail, and reduce spillage at higher sections of the genoa
See for yourself.
Old 03-30-2008
I'd second the idea of trading the pole for a proper whisker if you have no plans to use a spinnaker. A bastardized spinnaker pole will be heavier than a proper whisker pole and less versatile, as you already know.
Should you decide later to use the spinnaker the modified pole will not work well in most cases (whether too short or too long).
1984 Fast/Nicholson 345
Old 03-30-2008
Unless its CF
Old 03-31-2008
I know all about the proper uses of spinnaker poles and a whisker poles.
No room to store both. I thought I could make my own spinnaker pole for less then a 1/3 of the cost of a new one. Just trying to be frugal with something that could work 90% of the time. Just a cruiser with no intentions of going high tech.
Refining Your Downwind Sails Brian Hancock Gear and Maintenance Articles 0 04-06-2004 08:00 PM
Spinnaker Fundamentals Steve Colgate Learning to Sail Articles 0 06-24-2000 08:00 PM
Spinnaker Fundamentals Steve Colgate Seamanship Articles 0 06-24-2000 08:00 PM
Spinnaker Fundamentals Steve Colgate Gear and Maintenance Articles 0 06-24-2000 08:00 PM
Spinnaker Fundamentals Steve Colgate Racing Articles 0 06-24-2000 08:00 PM
