Old 03-30-2008
trantor12020's Avatar
trantor12020 is on a distinguished road
Raymarine Rudder Reference Unit problem
For want of better autopilot control in lumpy sea, I installed a new Rudder Ref Unit to my ST4000+ MKII Wheel Pilot. Problem is even after setting to "Steering Bar" in the User Setup, I don't see the bar in Standby Display.
Changing to "Rudder Bar" didn't help either. The Ref Unit is correctly installed and mechanical alignment triple checked to be ok. I wrote to Raymarine for answer but doubt I'll get response within days. So any experience sailor out there can help ?
Ken
2002 Hunter 326, SV Millennium 2
1999 Macgregor 26X, SV Millennium
Old 04-06-2008
Ok, problem solved. Raymarine replied with instruction.
In Dealer Setup, select Tiller mode and save, Then go back and select Wheel mode and save. This reset the ST4000+ unit and viola! the rudder ref unit works.
Ken
Rudder Bearings billyruffn Gear & Maintenance 25 02-03-2008 10:44 AM
Rudder Post Problem nauticalrich Gear & Maintenance 3 04-08-2003 06:13 PM
Rudder vibratrion taimer Gear & Maintenance 2 11-04-2002 06:06 PM
Fiberglass hull and rudder problem Jeff_H Boat Review and Purchase Forum 0 08-01-2002 05:09 PM
cracked rudder aasault Gear & Maintenance 0 10-10-2001 03:30 PM
