Binocular Suggestions - Page 4 - SailNet Community
post #31 of 54 Old 04-02-2008
XTR
Originally Posted by T37SOLARE View Post
I have both a set of Tasco 7x50 Offshore w/compass ($175+/-), as well as a pair of the Fuji 12x35 stabilized.
Surprisingly, I find the 12x35's to be brighter at night than the 7x50's but that may have to do the higher magnification factor.
It may have more to do with the fact that they're Tasco's. I've done a fair share of shooting in my life and with a single exception that I know of Tasco glass is not the highest quality.
XTR is offline
post #32 of 54 Old 04-02-2008
Best Looking MALE Mod
Cruisingdad's Avatar
7x50's are pretty traditional, since they give you a good compromise of weight, size, magnification and low-light capability. The two numbers, in case you don't know are the magnification (7x what the normal eye sees) and the size of the objective lens (50 mm or roughly 2" in diameter).
Higher magnifications than 7x will generally be harder to handhold steadily on a small craft, which is where the stabiliized binoculars come in to play. However, stabilized binoculars require electricity to work... and if the batteries fail, the much higher (10-14x) magnifications on most image stabilized binoculars will be useless.
The Objective diameter divided by the magnification gives you the exit pupil diameter. On a pair of 7x50's it is about 7.1 mm. This is important for estimating the binoculars low light capabilities. Anything less than a 7mm exit pupil will generally be significantly dimmer than unaided vision, and may make it very difficult to read the markers through the binoculars. They do make "night-vision" equipment that can help with this, but again, the NVG gear is close to useless if the batteries die.
A few other things to consider:
Focusing: Center or individual. Most waterproof binoculars have individual focussing, since it is easier to design a waterproof binocular that tway.
Eye Relief: This is especially important if you wear prescription glasses. The better ones have almost an inch of eye-relief....which means your eyes can be an inch away from the eyepiece and still see the whole image properly.
Compass: You can have an analog or digital compass built into the binoculars. This makes taking a bearing very simple. The digital ones are often easier to read, at least until the batteries die. I prefer the analog compasses.
Waterproof: Yes, they should be both waterproof and nitrogen filled. Non-nitrogen filled binoculars will generally have issues with condensation internally in colder weather.
Floatation: You should either get a floating strap, usually with foam or neoprene padding, or get a set that floats. You will eventually drop them in the water, and it is best if they don't sink.
Rubber Armor: The better marine binoculars have rubber armor to help protect the binocular's optics from shock in the case that you drop them. You will drop them... so do your boat's gelcoat, your binoculars and your toes a favor and get them with the rubber armor. This also makes them easier to grip in bad weather and makes them warmer to hold in cold weather.
Finally, a good pair of compact binoculars, for general daytime use is a set of 8x30 binoculars, like the Steiner's shown here:
They're about two-thirds the size of the 7x50s I use at night, and give you a tiny bit more magnification. These live in my daybag.
Does anyone know if that floatation strap really works? I kinda feel like it is useless. Why? Because if my $600 binoculars fall in the drink, I am jumping in after them regardless of that strap.
I would honestly apprecaite it if someone with a pair of $1000 Steiners or $600 Fuji's would tie that strap on their binocs and throw it in for me. Report back (with pics) and let me know if it floats, would ya?
Any takers??
- CD
Sailnet Moderator
My Website:
Follow My Blog at:
Follow me on Facebook:
Cruisingdad is offline
post #33 of 54 Old 04-02-2008
Señor Member
TrueBlue's Avatar
The ads claim it FITS all 7x50 Stieners, but doesn't say it FLOATS all of them.
Don't have one handy - otherwise it would be an excuse to leave the office and head for the waterfront.
True Blue . . .
sold the Nauticat
TrueBlue is offline
post #34 of 54 Old 04-02-2008
My crew tested the flotation strap on my WM 7x50s... and yes, they work...I don't let the crew dogz use my good steiners...
Any takers??
- CD
sailingdog is offline
post #35 of 54 Old 04-02-2008
TB,
How far are you from SD? He will let you borrow his!
- CD
PS I have that same strap (on my fuji's) but it only came with the cheaper model. Makes me wonder if it would float the Polaris too.
Sailnet Moderator
My Website:
Follow My Blog at:
post #36 of 54 Old 04-02-2008
Señor Member
TrueBlue's Avatar
He's in Boston, I'm in Newport - about a 90 minute drive. Think I'd not try it in water deeper than my kneecaps though. . . . harbor water must be 38-40 degrees.
True Blue . . .
sold the Nauticat
TrueBlue is offline
post #37 of 54 Old 04-02-2008
water's still a bit cold this time of year.
post #38 of 54 Old 04-02-2008 Thread Starter
Wannabe Sailing Bum
Vitesse473's Avatar
Again, really excellent advice and I hope this thread helps others figure out what is best to buy. We have the All Sail boat show coming up here in the SF Bay, so I am hoping both Steiner and Fuji are present. I am glad the thread also morphed into how to keep them afloat. Would those straps work for my winch handles too?
Vitesse473 is offline
post #39 of 54 Old 04-03-2008
Steiner, Fuji, Nikon and Canon all make excellent glass for their optics. Going with any one of the four would be a pretty safe bet.
post #40 of 54 Old 04-03-2008
Boasun's Avatar
Tie a retrieving pendant to the "Floating Strap" then you won't have to go wading. Gesh!!? Here is your sign
Boasun is offline
Suggestions for a stiff boat newuser Boat Review and Purchase Forum 17 07-21-2013 11:39 PM
Boat Suggestions dagerman Boat Review and Purchase Forum 14 09-11-2006 03:42 PM
How to start a sailing club - Suggestions? thenrie General Discussion (sailing related) 0 06-30-2006 07:13 PM
Health Insurance?.... Mail? ...Any Suggestions? hcsorrell General Discussion (sailing related) 0 09-30-2004 01:11 PM
BVI suggestions rleslie Chartering 8 01-31-2004 04:45 AM
