Repainting Interior - Page 2 - SailNet Community
post #11 of 20 Old 04-01-2008
Here .. Pull this
Ahh - fun with Tofu ! Looks like good stuff. Had never hear of it before.
Sailormann is offline
post #12 of 20 Old 04-02-2008 Thread Starter
johndotson's Avatar
I found a whole bunch of really good reviews so I thought it was worth a shot, furthermore weighing in at almost 3000 lbs she could stand to loose a pound or two eating some Tofu shouldn't hurt.
johndotson is offline
post #13 of 20 Old 04-02-2008
SaltwaterSuzi/CapnLarry
LarryandSusanMacDonald's Avatar
SaltwaterSuzi/CapnLarry:
It is just fiber glass no gel...
I would advise against using the latex. When the boat "sweats" it will stain. If you can get the old paint all off - rough up your surface a bit - even a wire brush will do - and roll on a high quality oil based paint - Petit makes some good ones - any of the gloss Z-Spars will work - and you can clean them. Roll it on with a roller soft enough to conform to the roughness of the fiberglass. Have rags and mineral spirits handy to wipe up the drips before they dry. Finish the tight places the roller won't reach with a brush.
Because it's on fiberglass, it's probably too rough to sand effectively for a second coat. If you time it well, when it sets up enough you can apply a second coat without sanding. Depending on temperature it should be somewhere between one hour and four. The first coat should be sticky to the touch but not come off on your finger. That well you'll get a "Chemical" bond. (Sanding gives a mechanical bond).
Use plenty of ventilation. Reward yourself with a libation of your choice when the job is finished. Maybe two.
Have to go, Saltwater Suzi just informed me that dinner is served.
Saltwater Suzi and Cap'n Larry
"A sailboat is a fickle mistress. You’ve got to buy her things. You’ve got to understand everything about her. What you don’t know she’ll use against you." -Captain Larry
LarryandSusanMacDonald is offline
post #14 of 20 Old 04-02-2008 Thread Starter
johndotson's Avatar
Thank you sooo much, Cap'n Larry!
I hope to have some photos when I am all done.
post #15 of 20 Old 04-08-2008
John (61 PE): Everybody has an opinion, eh? Scroll down to the advise the pro gave you (Capt Larry) and start from there.
Good luck!
Wishbone
Wishbone2 is offline
post #16 of 20 Old 04-08-2008
Painting interior
Let me add another element to the discussion. I need to repaint the cuddy of my '68 Daysailor. West recommends Petti Dura-White - a latex. The current paint has a blue streaks to hide the imperfections. Does anyone know of an additive - color chips or flakes - that can be added to the paint to recreated the look and hide the imperfections?
kokko is offline
post #17 of 20 Old 04-08-2008
artbyjody's Avatar
Goto any artist / crafts related store - you can metallic chips and other powder that you can mix into it do give that effect...
-- Jody
S/V "
1983, Barberis Show 38! or
artbyjody is offline
post #18 of 20 Old 04-08-2008
A flocking gun is good at hiding imperfections. Or ceiling popcorn. (UGH!)
Ah, seriously though...check out Martha Stewart's stuff, or any of the big box stores' paint departments, there are all sorts of fairly easy ways to add fake texture and effects with paints these days, it all depends on how crazy you want to go. They should work just as well with "marine" paints.
Marine "epoxy" and "urethane" based paints are pricey--but they hold up way better than anything else, if you've done a good prep job so they can bond well.
hellosailor is offline
post #19 of 20 Old 04-11-2008
House Paint
Check in Don Casey's This Old Boat on which house paints to use.
ssmith8523 is offline
post #20 of 20 Old 04-11-2008
Owner, Green Bay Packers
Casy recommends exterior house trim paint, an alkyd enamel, which translates out to oil-based house trim paint. I did my boat with it, and prep is everything, to good effect.
Wm. F. Buckley, Jr.
sailaway21 is offline
Hull Hard Spot leading to Interior Refit Blueskyzephyr Sailboat Design and Construction 9 01-16-2008 04:44 PM
fastening to cabin fiberglass cabin interior marcusn Gear & Maintenance 3 09-06-2007 07:04 PM
Interior Paint ian6460 Gear & Maintenance 4 11-26-2004 07:23 AM
Interior work sneuman Gear & Maintenance 2 01-02-2004 02:16 PM
Interior Cushion Storage Steve Meadows Gear and Maintenance Articles 0 10-23-2000 08:00 PM
