04-01-2008
Brezzin-
When the boat is anchored out in storm conditions, the wind is usually such that an all-chain rode would be stretched taut, meaning that there is no catenary curve to the rode. A combination rope-chain rode will not shock load the boat or anchor as much since the nylon portion of the rode will stretch quite a bit. The all-chain will shock load the fittings on the boat, and the shockloading may cause the anchor to break out of the bottom.
