04-03-2008
Polishing fuel is basically taking the fuel from the tank and passing it through fuel filters over and over again to remove as much of the crud and particulates from the fuel as possible. It usually involves a fuel pump and two or more fuel filters. The first is usually a 30 micron water separating filter, and the second is usually a five micron filter or so.
This is done to help prevent fuel-contaminant related issues when the boat is using the fuel. This is especially important in bad weather, when the motion of the boat may bring crud off the bottom of the tank.
Originally Posted by H216Sailor
Pentegingras,
No afront taken, espeically on a rainy day for you. In my novice state, it would be helpful if you could define what "polishing diesel fuel" involves.
Thanks again,
H216 Sailor
