04-01-2008
SaltwaterSuzi/CapnLarry
Shouldn't be a problem. Check your circuit breaker for that circuit and make sure you don't exceed its rating with everything else that's on the circuit. Also, make sure the wire to the bulkhead light will handle the load. Small fans don't draw that much so it should be OK but you always have to consider all factors.
Saltwater Suzi and Cap'n Larry
"A sailboat is a fickle mistress. You’ve got to buy her things. You’ve got to understand everything about her. What you don’t know she’ll use against you." -Captain Larry
